Author: Subject: Welding a swing set bracket
Slimy38
posted on 29/3/18 at 10:35 AM Reply With Quote
My daughter has a swing set made from wooden poles (similar to horse jump poles, about 120mm thick). The swing is fixed on with a couple of galvanised metal straps, and she's managed to break one (it is about 10 years old after all!). I'm ordering a new strap, but it would be typical that it happens just before the easter holiday when I'm working away.
I'm thinking of welding up the current one, is there anything I should be mindful of or is it a fairly straightforward fix? I was planning to grind off the galvanised coating so I don't get fumes, then a quick coat of red oxide just to protect it.
It's this type, and it's broken where the metal is bent at 90 degrees;
Mr Whippy
posted on 29/3/18 at 11:32 AM Reply With Quote
If your using wooden posts for the frame like I did then I used these -
linky
seem to be lasting very well and stronger than those brackets, no wonder they broke
Slimy38
posted on 29/3/18 at 11:51 AM Reply With Quote
It's more to get her sorted just for the week, I'm ok with the strap itself considering it's been used pretty much every day for at least ten years. We've replaced the seat itself three times because either the seat or the rope has worn out!!
liam.mccaffrey
posted on 29/3/18 at 03:35 PM Reply With Quote
I've found a great way to remove galv is to leave the part you want stripped soaking in vinegar for a few hours
Build Blog
Build Photo Album
liam.mccaffrey
posted on 29/3/18 at 03:36 PM Reply With Quote
Build Blog
Build Photo Album
Angel Acevedo
posted on 29/3/18 at 07:21 PM Reply With Quote
Go ahead.
Even holding your breath may suffice as is a very short weld....
When I weld galvanized I grind because I feel I can weld prettier...
Grinding the coating produces dust.. Therefore wearing appropriate PPE is needed.
owelly
posted on 30/3/18 at 10:39 AM Reply With Quote
Tie the rope for the swing round the pole......
http://www.ppcmag.co.uk
posted on 30/3/18 at 01:14 PM Reply With Quote
Originally posted by Angel Acevedo
Go ahead.
A gentle cross-draft helps as well...
big_wasa
posted on 30/3/18 at 04:47 PM Reply With Quote
Just grind the galv back and crack on. I would do it for you if you where closer. But rope or chain around the pole is a good idea.
907
posted on 30/3/18 at 10:08 PM Reply With Quote
Triggers Broom
