Author: Subject: ETB oil pressure sender required
andyace
posted on 31/3/18 at 09:02 PM Reply With Quote
Hi all,
I have a 2.0 Pinto and need to get an oil pressure sender for my electric ETB oil pressure gauge (90psi 0-6 bar)
I think the one is like the one in the link below .... seems rather expensive !! anyone know if there is a cheaper alternative ?? (needs to be 0-6 bar)
https://www.etbinstruments.com/index.php?route=product/product&path=99_103&product_id=75
Ian2812
posted on 1/4/18 at 01:26 AM Reply With Quote
Andyace,
For a brand new actual OEM part, I'd say £33 inc the VAT is pretty reasonable...
VDO senders are anywhere from £50 - £110. (Just replaced mine the back end of last year.)
eBay have cheaper after market ones for around £20 up over but you take the risk of poor imports not to the OEM spec.
For the sake of a £13 saving... I'd go for the OEM part every time...
tims31
posted on 1/4/18 at 02:47 AM Reply With Quote
Originally posted by andyace
Hi all,
Thats the one I have fitted to a gauge and also gives me a light on low pressure (too late though) hence why I use the gauge.
As said, £33 isn't too bad I thought.
Build: http://www.martinsfurybuild.co.uk/
andyace
posted on 1/4/18 at 09:31 AM Reply With Quote
Thanks guys,
yeah having looked around I think i'm coming to the same conclusion, don't fancy bodging in some import sender
Looks like it's time to bite the bullet .... that's a chunk off my £250 budget for the car
andyace
posted on 1/4/18 at 09:35 AM Reply With Quote
As far as fitting an oil sender, should anything be used on the thread ???e.g. PTFE tape to avoid any leaks ?
ian locostzx9rc2
posted on 1/4/18 at 10:54 AM Reply With Quote
If the treads are good you shouldn’t need to use anything.
Ian2812
posted on 1/4/18 at 01:09 PM Reply With Quote
Definitely do not use anything on the thread.
The thread on the sender is tapered I.E. NPT... It will seal.
The sensor works using a resistor to earth. If you make a higher resistance between the sender and your engine you will get a false reading on your gauge, a higher pressure reading.
A dead short to earth = 0 bar.
Open circuit or very high resistance = Full, off the scale pressure indication.
Hope that makes your decision easier for you...
I had an issue with mine last year, need to do a write up on it as It was a bit of a learning curve at the time.
Ian.
Ian2812
posted on 1/4/18 at 01:10 PM Reply With Quote
Ian.
andyace
posted on 1/4/18 at 02:23 PM Reply With Quote
Thanks Ian, that all makes good sense, I need to also use the adapter to take it up to 1/4NPT as its a 1/8 sender.... so nothing at all on the threads for both adapter and sender, cheers
Ian2812
posted on 1/4/18 at 04:24 PM Reply With Quote
https://www.etbinstruments.com/index.php?route=product/product&path=99&product_id=79
Like the above?
Yeah, both tapered treads. No ptfe or paste.
Clean metal to metal to give good continuity for chassis / engine earth.
If there is any oil weeping, just give it a further nip up.
Ian2812
posted on 1/4/18 at 08:01 PM Reply With Quote
Andyace
http://www.locostbuilders.co.uk/viewthread.php?tid=212062
Got this written up tonight. Might help.
Cheers.
