Author: Subject: Black wire behind dash
Mark100
posted on 4/4/18 at 12:14 PM Reply With Quote
Ok so I have this black wire come off the back of my lights stalk as I was putting the dash together
I sent the stalks off to get it all wired with the loom so didn't assemble it in the first place
That and I have no idea about electrics to start with
does anyone now whitch terminal it came off
there are 4 at the top and a spare at the bottom
Im guessing its a ground wire ?? How would I find the ground terminal ???
[img]IMG _20180403_193652 by Mark Snee, on Flickr[/img]
Thanks Mark
tims31
posted on 4/4/18 at 12:55 PM Reply With Quote
The first thing I would try is to connect a multimeter to the black wire and an earth point on the chassis and see if it is connected to earth.
The diagram below is for the wiring of Sierra stalks on the right hand side
Have you tried all the functions for that side of the stalks, wipers, washer, side and main lights? Also maybe the horn?
[Edited on 4/4/18 by tims31]
Build: http://www.martinsfurybuild.co.uk/
posted on 4/4/18 at 01:55 PM Reply With Quote
Ditto, check it's earth with a multi-meter between the wire itself and the chassis (which should be earth).
Mark100
posted on 4/4/18 at 02:34 PM Reply With Quote
what will the multi meter say if it is an earth ???
from there looks like switched erath for washers and wipers (I have neither ) does that make a difference ??
Thanks for the help
tims31
posted on 4/4/18 at 03:28 PM Reply With Quote
Thanks for the help
Do you know how to chek continuity? Have a look on Youtube for a guide on how to use a multimeter to check continuity, normally it has a 'beep' function so when checking between two points you will get a beep to tell you you have made a circuit, thats what you will do when connecting between the black wire and a point on the chassis if it is an earth.
posted on 4/4/18 at 03:29 PM Reply With Quote
Most mulyi-meters I've seen and/or used have a beep (continuity) feature. This shows you if there's 0 Ohm connection between two points.
steve m
posted on 4/4/18 at 06:27 PM Reply With Quote
With the ignition on, put a nail in the hole, and stick your tongue on the nail
with one of your spare hands dip in water first , and hold the chassis or any bare metal
If you scream in agony, and have burnt your tongue, ITS LIVE
if not its a spare earth,
Mark100
posted on 4/4/18 at 06:47 PM Reply With Quote
Ok watched a few you tubes on multi meters and tested it for continuity so it is an earth the did the connectors and they show earth's at 53c and w ??? Does it matter as long as it's an earth ?? Think I'll give the tongue test a miss and watch more videos. Cheers lads
tims31
posted on 4/4/18 at 07:59 PM Reply With Quote
If it is from 53c then is your screen washer working or do you have it wired to a different switch?
Have you tested the functions of all the items for those switches on the right hand stalk?
Mark100
posted on 8/4/18 at 01:14 PM Reply With Quote
No screen so have a few spare tried the earth on 53c and it seemed fine till I flicked the lights on loads of smoke in a couple of seconds burnt the black wire and a couple of others near it now nothing on the colum works but the car still runs anyone now a auto sparky in leeds
ReMan
posted on 8/4/18 at 01:22 PM Reply With Quote
OK another approach!
Before the smoke and fire was anything NOT working?
If your lucky you've blown a fuse, but it does not sound great.
The problem is knowing how anything is wired.
I take it you only have lights indicatiotsrs and horn on the columns and no wipers/washer
[Edited on 8/4/18 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
posted on 8/4/18 at 09:19 PM Reply With Quote
Too late now but why did you think connecting an unknown wire to earth would be a good idea? What was not working that you thought this would fix.
If wires are melted then the copper is likely to be shorting out meaning there is a lot of work tracing the circuits and replacing the wiring. If you are lucky, then a fuse will have blown a few wiring saved.
At the end of the day, it's just a bit of time and money, you aren't the only one to have made a mistake.
Mark100
posted on 9/4/18 at 09:34 AM Reply With Quote
Yep fuse popped
The cars all fine just lights all was ok till I pulled the main beam flasher and bang
Im just leaving the electrics alone now and trying to find a sparky that will take a look for me you'd be supprised
how many companys don't want to know when you say kit car
" Yes we will come out what car is it a locost what ????? NO NO NO SEE YA "
