Author: Subject: 13" Minilites - Will they fit?
chrisbmxr
posted on 20/4/18 at 02:30 PM Reply With Quote
Will these fit an MK Indy? I know the PCD is correct, but will they go over the brakes (standard disc brakes all round). They came off a Mk2 Escort.
They are 13"x7j, 4x108 ford fitment et-7
Sorry for asking a stupid question ... I'm not good with offsets etc.
I take it some arch work would be required as they'll sit wider than my current 15"s which have a standard offset?
Thanks again for your help!
Chris
big_wasa
posted on 20/4/18 at 02:57 PM Reply With Quote
offset is miles out. Your Indy should be more like 35~38. I would love a set for mine but they just don’t look the same with the Sierra offset on a 6or 7j rim.
[Edited on 20/4/18 by big_wasa]
chrisbmxr
posted on 20/4/18 at 03:10 PM Reply With Quote
OK thanks!
Shame - they would look awesome!
big_wasa
posted on 20/4/18 at 05:19 PM Reply With Quote
Assuming your current rims are 6” with an offset of +38 and the new ones are 7” with an offset of -7 the new rims would stick out another 57mm ish.
There are several online calculators and your Indy may be differant to the normal.
CosKev3
posted on 22/4/18 at 09:23 AM Reply With Quote
The lowest offset and size you can use on the Indy with standard rear arches keeping the wheels inside your rear arches will be a 6 inch wide ET24 wheel.
chrisbmxr
posted on 26/6/18 at 10:24 AM Reply With Quote
I take it I would have the same problem with these ...
https://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=212786
Sorry to ask again, I'm not good with offsets!
CosKev3
posted on 26/6/18 at 11:50 AM Reply With Quote
Yeah.
A good site to use is www.willtheyfit.com
Type in your current wheel sizes and then your new ones and it shows you how they would sit on the car,and speedo/ride height differences
MikeR
posted on 27/6/18 at 12:50 PM Reply With Quote
If this means they could be for sale I could be interested
jps
posted on 28/6/18 at 08:21 PM Reply With Quote
I *think* that mk1 Ka wheels have close enough offset to replace 'Sierra' wheels. And there were some mini-lite style wheels on one of the Ka models. .. Might be your best bet?
