Author: Subject: new build rear engine midi
bart
posted on 29/4/18 at 10:59 PM Reply With Quote
Hi All
well I'm back in the saddle , health is better and my business is doing ok , so time to build a car
when I built the single seater it started as a two seater and sum how ended up a single seater.
so clean sheet start - back to a two seater
I some know I have spent the last months recovering from a hart attack and running a business ,got a bit bored so planed and
designed my new project
the design is now at a stage where I can make the chassis
this is a side view
spec is exo skeleton taking big hints from several designs
it has a square face bottom to allow easy of build and panel attachment
the top half ( floor up ) is all round tube
front suspension is hi spec uprights
engine and gearbox is Toyota Celica gts 190 hp ( turbo charged expecting around 350 hp at the crank )
rear suspension is all unique ,
all arms and geometry is unique
i have deigned it to take either front or rear rads , i will make the final desision when engine is in the frame
all the panels are simple flat cut out coloured aluminium
colour scheme will be gloss red and black chassis
today i turned up the rollers to make all the rolled sections , up till now i ahve also machined the suspension
bushes and a few tooling aids.
the plan is to make all the chassis tubes over the next few weeks
i will make a chassis table soon ect
hope to post regular up dates and pics.
BE ALERT > BRITAIN NEEDS LERTS
View User's Profile View All Posts By User U2U Member   bart 's Aim
bart
posted on 29/4/18 at 11:12 PM Reply With Quote
chassis pics cad
just a few jpegs of chassis design
as you can see it has a centre tunnel to give extra strength and somewhere for possible rad tubes and gear change cables
[Edited on 29/4/18 by bart]
bart
posted on 29/4/18 at 11:36 PM Reply With Quote
engine pics
I choose this engine for the following reasons
1) the rev like a bike engine
2) they turbo charge really well
3) forged rods and crank as standard
4) variable cam and lift
5) light weight
6) exhaust will be at the rear of the car
7) gear box is good for 350 bhp ( crank ) after that its a grenade !
engine pic front on view
rear view
as you can see I have the turbo mocked up in position and all the bitts I don't need taken off
I have already designed a new belt root
it will have a moroso baffled sump.
I was going to build my own turbo manifold , but some things have to give as my work capacity is not what it used to be.
and decided it was not worth the extra effort , although I did design it .
bart
posted on 29/4/18 at 11:51 PM Reply With Quote
more layout jpegs
a few more general layout pics
If you thinking it only has 3 wheels and one side suspension , I only draw what I need if it is to be mirrored
yes I am lazy and I don't care !
front view
rear view
top view
rear suspension view
Bigboystoys
posted on 30/4/18 at 08:02 AM Reply With Quote
Pleased all has improved after the heart attack, the drawings look amazing really looking forward to seeing this progress.
posted on 30/4/18 at 08:11 AM Reply With Quote
Glad health and business are back on track and glad to see you back designing and building as well.
Personally I've always liked the idea of your proposed layout. IMHO it opens up big possibilities for using a wider range of FWD car engines/transmissions in a build.
Please keep us posted on your progress with pictures and words!
bart
posted on 30/4/18 at 09:20 AM Reply With Quote
further info
good morning all.
having posted this last night late I realise the errors . failing eyes as well
and you never write what you thought you did
few more specs in no particular order - as they fall out of my brain .
wheel base is 2250 very go cart like
track is 1497 front and rear , uses standard drive shafts ect.
it is designed to take the larger framed gentalman !
1200 wide in the cockpit and long enough for 6 ft 8" or so
wet car aiming for 520 kg on track so far
driver is trying to loose weight !
looking to be 350bhp ish.
tyres are 195 /50 I don't feel the need for bigger
no windscreen although there will be wind deflectors
road legal going for IVA
most panels will be inset in the frame , so chassis can still be seen and makes IVA exoected rads easy to achieve.
at the moment a few cross tubes are missing to brace suspension pionts
i will add them when engine is in ect i have a few idears but easier to work round and with other components.
lots more to report but my breakfast tea is running out so its off to the kettal ( ie shout the wife )
as more comes to mind i will post updates.
ohh one more thought , the chassis front and rear where level for a long time and to be honest it looked slightly better but it made the step in to high after I did a temp build : ie a bit of plastic tube 2 chairs and a few books. I'm old and stiff and would have found it "difficult" to get in and out , and I'm not getting younger, so hence the last minute drop in chassis height more seven height now , well half way between what I had and a seven .
[Edited on 30/4/18 by bart]
MikeR
posted on 30/4/18 at 11:05 PM Reply With Quote
Hope you don't mind, when i saw the diagram I thought the back looked a little (don't have the right word but something didn't resonate with me). I'm absolutely no artist but i've had a very quick play on paint and tried to add curves. I'm not sure its better but figured if i share it, it may reinforce your view of your design or inspire you to do something different.
alternate view
alternate view
Ugg10
posted on 1/5/18 at 01:18 PM Reply With Quote
Welcome back and glad you are recovering well.
Looks like a good project. if you can make the rear prettier than the Exotec then that would be a good thing. Stuart Mills did a version of the Rocket with the Celica 190 engine but don't think it saw the light of day, this was when he was updating it to have a more pointed front end, he also did a v6 version for a customer IIRC. Any reason you went turbo as Lotus used a supercharged version of this engine in the exige/evora IIRC to get 350hp.
http://www.totalkitcar.com/2016/06/09/onwards-and-upwards/
Good luck and will be following closely.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
bart
posted on 1/5/18 at 03:10 PM Reply With Quote
engine and rear frame
Thanks all for the reply's
first rear frame
I always find the rear frame on an rear engine car the most difficult
as basically you have a tall engine to accommodate and it is just a "big hole" to get around
I have a much higher back than most to stop big tall engine covers ,
I am thinking style the rear when I can see what I truly have to get around.
I have some ideas double hump fast back , flattish with a flip up etc etc
I am trying to avoid fibre glass moulds this time , although I think the rear engine cover may have to be fibre glass.
don't mind doing a mould if you know my previous work but the mess is incredible !.
might have to do side scoops for rear radiator if I go that route as well .
may go down the aluminium route, I fancy a go a shaping my own panels.
we shall see
re engine > well why did I go down the 2zz-ge route.
simple answer > it seemed like a good idea at the time.
why the turbo rather than supercharger. couple of reasons
1) to much noise just behind drivers head
2) parasitic losses
3) capped at about 320hp > I was originally going for 450-500hp - had a rethink on that though now 350 ish
ps these engines can do 450,500 quite easily
I think originally I was going for the 1600 Eco boost engine , but the exhaust is on the wrong side , loads of heat behind driver.
I think you can go on for years deciding which way to go , and sooner or later you have to put your cards on the table . and work with that decision.
again we shall see .
thanks for your comments all welcolm.
ps: i had a look at the side view redesign that MIKER propposed , when looked at in 3D , think it would be difficult to make it work . especialy with the rear engine cover and possible side scoops . " but any out the box thinking is always welcom.
well im off to teach myself tig welding that should be hours of "oh S--T" "B---r" ect ect.
could well end up going back to mig welding it all !
good by for now folks.
bart
posted on 10/5/18 at 03:11 PM Reply With Quote
further update build starts
hi all
well got some time off today and made start
first the build table made as small as possible to get around and work
can you spot the mistake
spotted it after I took the picture and corrected it.
measure twice as they say , good job I was not cutting it in half !
next picture you can see the flat pattern clued to the table
i had to split the drawing and stretch the length as for some reson my plotter does not print scale in the long axis.
got fed up trying to correct it so just cut the drawing in half . and added 9 mm gap to correct the error .
yes yes i know every thing is slightly out but it wont hurt .( i shall retract that statement if it all goes belly up )
tea time now, if i can raise the effort i will make the roll templates tonight for all the rolled pieces.
i have already made the rolling formers so should progress when work allows ( and wife )
bart
posted on 10/5/18 at 03:15 PM Reply With Quote
RE laser parts
final word for today
I had terrible trouble getting laser quotes done.
I sent the dxf/dwg files out to 6 companies , only got one company to quote.
any one else had similar problems , and yes I tried all the recommended companies from this forum
bart
posted on 10/5/18 at 07:58 PM Reply With Quote
first chassis parts made
late post for the day
I rolled the outer lower chassis rails tonight
came out perfect - a good start
there 1.5" x 1" fyi
bart
posted on 13/5/18 at 09:03 PM Reply With Quote
quick update
Hi all , just a quick update
finished the main tub floor fabrication
got the roll bar in position and cut round the main tub frame.
a few pics below
looking down the table with roll bar in position
better pic through roll bar
bart
posted on 27/5/18 at 08:48 PM Reply With Quote
a few updates
Hi all hope your having a good bank holiday.
just an update
I now have the main chassis finished
I need to add the cross braces ( triangulation where possible )
also need to add all the little bit's suspension points ect ect ect
and weld up but the shape is all there now.
so here we go
chassis nain tub top rails
fish mouth with multy compound angles and rolled section , quite pround and pleased with these.
chassis front not finished but showing rack in place
chassis from rear getting near now
close up of rear
front with lower bar in place
another rear view
another view of the front
to finish i sat in the car today for the first time , every thing seems to be ok all in the correct place.
have a friend comming round tomorrow to mark up wheel posistion , gear change , brakes etc etc
funny , when i sat in the car for the first time did all the usual sound affects ( what a pratt im 60 for god sake
[Edited on 27/5/18 by bart]
bart
posted on 11/6/18 at 09:22 PM Reply With Quote
further update
Hi All
sorry no recent post.
however , I have installed the front suspension
reinstalled the steering ( moved rack )
radiator installed
steering complete
started on finishing mid tunnel
had a proper sit in the car
next step is to install seat belts
seat structure next
working my way to the back of the car.
pictures explain themselves no particular order.
AdamR20
posted on 13/6/18 at 11:41 AM Reply With Quote
Looking great! I love the way you work, just get stuck in and deal with whatever comes your way
I've had decent success with a couple of laser cutting companies - AK Stainless in Bamber Bridge (Preston) and Microkerf (Leicester). The second are a bit cheaper but obviously further from you.
Adam
