Author: Subject: Fisher Fury suspension installation
Stuart15
posted on 11/5/18 at 03:50 PM Reply With Quote
Good afternoon,
I am looking for advice/reassurance on installing new shocks on a fisher fury, particularly the rear.
I bought some nice shiny new shocks from Protech to replace the old Spanx units and need to get them installed fairly sharpish before my suspension setup and subsequent track day. I bought rather than built the car and whilst access to the front suspension looks fairly simple, access to rear looks a lot more awkward. Is it possible to change the rear shocks without removing the bodywork and just jacking the car up?
Thank you in advance,
Stuart
adithorp
posted on 11/5/18 at 03:58 PM Reply With Quote
Yes, they are removable without taking any bodywork off. ...or at least they should be unless the builder put the top bolt through in the wrong direction and the fuel tank is now in the way.
http://jpsc.org.uk/forum/
Stuart15
posted on 11/5/18 at 04:08 PM Reply With Quote
Excellent, hopefully that'll all be fine then! Thank you for the response.
tims31
posted on 11/5/18 at 04:56 PM Reply With Quote
As Adi says they should be fine. Have a look on my build blog and there are some images of the shocks fitted without the bodywork showing. Is yours IRS or Solid axle?
images here
Build: http://www.martinsfurybuild.co.uk/
Stuart15
posted on 11/5/18 at 05:43 PM Reply With Quote
Brilliant, thanks. I've only had it a week, I'm not actually sure if it's got IRS or solid axle. I'll have a poke around over the weekend.
