Author: Subject: Zetec went bang
S1502
posted on 17/5/18 at 06:49 PM Reply With Quote
Zetec went bang
So went out this evening for my first blast of the year.
Then the car goes bang and dies.
Plenty of fuel now wont start. Turns over but wont fire. Any ideas am starting to panic the engines blown.
Its a silvertop zetec running injectors and an efi intake.
Was running fine previously.
James24785
posted on 17/5/18 at 07:14 PM Reply With Quote
Does it sounds like its turning over like normal, or is it spinning faster on the starter?
S1502
posted on 17/5/18 at 07:31 PM Reply With Quote
Was turning over like normal nothing sounded different
Ugg10
posted on 17/5/18 at 07:48 PM Reply With Quote
Have you checked compression, has the timing belt slipped/broken?
Basics check spark, fuel, compression?
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
S1502
posted on 17/5/18 at 08:14 PM Reply With Quote
Theres fuel in the rail and the pump is priming. Spark plugs look fine but will test tomorrow.
Need to buy a tester to check the compression
gremlin1234
posted on 17/5/18 at 08:30 PM Reply With Quote
my first guess would be a fuel problem
was/is the fuel standard unleaded?
specifically, most modern fuel contains alcohol, which if left for signification periods, can absorb water from the air, and can then separate, leaving water at the bottom of the tank. (and engines don't run well on water! )
melly-g
posted on 17/5/18 at 08:42 PM Reply With Quote
You say it went bang?
Did you hear a bang through the exhaust? Or somewhere else?
S1502
posted on 17/5/18 at 08:45 PM Reply With Quote
Through the exhaust sounded like a backfire.
The car spluttered slightly then popped
James24785
posted on 17/5/18 at 08:57 PM Reply With Quote
All belts look in place and tensioned still ok?
S1502
posted on 17/5/18 at 09:03 PM Reply With Quote
Yeah all in place and all tensioned fine.
Was completely random had been driving fine this afternoon then stutter backfire and dripped out.
melly-g
posted on 18/5/18 at 04:50 AM Reply With Quote
Check all the wiring connectors, crank sensor OK and connected? Coil OK? Have you got a spark?
HowardB
posted on 18/5/18 at 07:53 AM Reply With Quote
sounds like a fuel / ignition problem, had an issue on mine where it lost the temp sensors air and water as it happened randomly changing the fuel mixture,.
have you checked for a spark?
Howard
melly-g
posted on 31/5/18 at 07:50 AM Reply With Quote
Have you got this sorted out?
S1502
posted on 31/5/18 at 08:25 AM Reply With Quote
Seems to be my spark plugs. Guessing they were dying and the engine over fueling then flooding. Started it ok two days later. Swapped out my plugs for a second set and now is running fine. Never had that before at all.
Tommes
posted on 5/10/18 at 08:30 AM Reply With Quote
Glad to have found this thread.
I have exactly the same behaviour with my car.
Big bang, car started to run bad and engine died .....wont start.
Compression has been tested, it is good.
Fuel is good,
The plugs dont look bad, all have the same colour, but they surely are old.
I ordered new ones and hope to have them today....
