Author: Subject: 12 Volt Feed Until Engine Starts
James24785
posted on 13/6/18 at 07:30 PM Reply With Quote
I want to illuminate the LED in my push button starter on ignition, but for it to then go out once the engine has started.
Can I simply double up on the feed to the oil warning light?
miskit
posted on 13/6/18 at 07:38 PM Reply With Quote
That would be a simple solution yes. Added benefit that it would come on with the oil warning light in case of a problem!
James24785
posted on 13/6/18 at 08:04 PM Reply With Quote
That's that sorted then, thanks
AdrianH
posted on 13/6/18 at 09:33 PM Reply With Quote
Or your battery charge light.
Adrian
Why do I have to make the tools to finish the job? More time then money.
Build diary at http://www.tamarisktechnicals.com/pages/roadster.html
gremlin1234
posted on 13/6/18 at 11:59 PM Reply With Quote
Adrian
that would (probably) work, but it's often used as an alternator 'sense' wire.
should be ok if using an led, but if lighting a bulb, it may cause problems.
I would use the oil light circuit
jossey
posted on 14/6/18 at 06:25 AM Reply With Quote
Or handbrake light
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
coyoteboy
posted on 14/6/18 at 12:00 PM Reply With Quote
Originally posted by jossey
Or handbrake light
Err, has nothing to do with engine starting?
Report your local potholes, it actually works!
jossey
posted on 19/6/18 at 08:08 PM Reply With Quote
Oh ye lol but you won't drive with it on haha
David Johnson
