Author: Subject: Removing BMW Automatic Gearbox
computid
posted on 2/7/18 at 06:44 PM Reply With Quote
Hi all,
Iíve broken an E36 328i auto as a donor for my E30. I need to split the engine and box now, but for some reason I forgot to drop the atf before I dropped the engine and box. I donít know much about autos and Iím concerned that once Iíve unbolted the TC from the drive plate and unbolted the bell housing Iím somehow going to end up with a workshop flooded with ATF if the torque converter falls off!
Any advice? Is this likely to happen or have I misunderstood?
Bikes: Yamaha XT660Z Tenere, Tuned Yamaha YZF-R1, in-build Turbo 2004 YZF-R1
Cars: A Minari RSR (Road Sport Racing) 1.7 16V Fuel Injected racer, a BMW E30 325i, a BMW E36 325i Coupe, a BMW E36 328i Vert, 2004 Vauxhall Astra H 1.8 SRI, 2010 Mazda 6 Sport 2.2TD, 2011 Range Rover Vogue 4.4 TDV8
posted on 2/7/18 at 07:08 PM Reply With Quote
Normally the TCstays on the gearbox and stops any leak , you will get some leakage from the oil cooler but the pipes can be capped. When the TCis undone just give it a little push towards the gearbox
