Author: Subject: IVA cat and tripod bearing questions
bart
posted on 3/7/18 at 12:28 PM Reply With Quote
Hi All
I have tried a search but nothing found , having said that bet its been questioned before
does the cat have to be E stamped for iva , I want to use a 3" 200 cell sports cat.
Tripod question not iva
does any one have the correct positions when installing a tripod joint
I presume at rest ie: neutral lift dive ect that the joint should be half way up the travel ,but then I suppose it depends on the intrusion into the joint under dive and rise , any thoughts ? also engine movement !
BE ALERT > BRITAIN NEEDS LERTS
Slimy38
posted on 3/7/18 at 01:22 PM Reply With Quote
There is no E stamp required for a catalytic converter, the 'proof of the pudding' will come when you have the car tested for emissions.
I've just had a look in the IVA manual and all I can see is that it needs to be secure, not leaking and not noisy.
MikeR
Contributor
Posts 8600
Registered 25/5/02
Location Hinckley
Member Is Offline
Photo Archive Go!
Building: Slowcost since 2000, speeduino since 2020, Caterha
posted on 3/7/18 at 01:33 PM Reply With Quote
Following as I'm interested in the tripod question
bart
posted on 3/7/18 at 02:12 PM Reply With Quote
The tripod bearing question is not IVA related more of a design question.
