Author: Subject: Running a remote oil filter and cooler query
will121
posted on 24/7/18 at 06:32 PM Reply With Quote
Due to clearance issues I need to fit a remote oil filter, is there any impact on engine oil flow or pressure on running a remote filter, thermostat and an oil cooler as setup in photo? Oil pipes to the oil cooler will be shorter on install.
[Edited on 24/7/18 by will121]
gremlin1234
posted on 24/7/18 at 08:12 PM Reply With Quote
there is a school of thought, that says having a thermostat in the oil cooler, will dump cold oil into the engine just as it gets hot. which may not be a good thing
bi22le
posted on 24/7/18 at 08:28 PM Reply With Quote
I'm confused with this picture. You have ( from left to right) a oil take off plate, a oil distribution block, a thermostat and the rad.
Why the distribution block? Or is it not that!
For info, I have a combined thermostatic and oil take off plate that runs straight to my rad. I saw no drop in pressure and had run fine when being spanked.
Please read my ring story:
gremlin1234
posted on 24/7/18 at 08:37 PM Reply With Quote
I think it for a remote filter
will121
posted on 24/7/18 at 08:47 PM Reply With Quote
It is a remote filter head just assembled without the filter.
Had the sandwich plate thermostat and oil cooler previously installed with no problem, but in the new install I can't fit the oil filter as it hits a chassis rail, hence addition Of The remote filter.
Thanks all
posted on 25/7/18 at 08:54 AM Reply With Quote
My Peugeot 205 1.9 GTI has a factory fitted oil cooler, but the oil filter itself is mounted directly on the engine block. Whilst I've never tracked the car there've never been any issues with it on the road in relation to oil temperature or pressure.
One factor I think many people don't allow for is the amount of engine running time it takes for the engine oil to warm up. The 205 has engine oil temperature and pressure gauges so the driver can actually see this process.
To qualify the above I've also had cars, including 2x 205 1.6 GTIs, without oil coolers. The 1.6 GTIs also took a fair time for the engine oil temperature to rise and settle.
[Edited on 25/7/18 by nick205]
coyoteboy
posted on 27/7/18 at 11:37 AM Reply With Quote
Thermostats aren't binary though?
Report your local potholes, it actually works!
CosKev3
posted on 28/7/18 at 08:33 AM Reply With Quote
That's rubbish,the thermostat in oil systems is never fully closed.
There is always a percentage of oil flowing around the system all the time.
The stat opens fully at the temp stated on it.
If the stat closed fully and opened up at high RPM you would probably kill the engine due to the drop in oil pressure!
rodgling
posted on 28/7/18 at 10:00 AM Reply With Quote
I have a thermostat and cooler on my car (the stat is attached to the block rather than remote but don't see why the exact location of the stat would make too much difference). It makes about 20 psi per 1k rpm when hot no problems (up to ~60 psi where the pressure relief valve kicks in).
The only thing I noticed was when I first filled the system, when it got hot enough to open the stat, I saw a momentary pressure drop as some air came out of the oil cooler, so make sure you warm it up on the drive the first time.
