Author: Subject: BEC cooling diagram?
number-1
posted on 13/8/18 at 08:06 PM Reply With Quote
Has anyone got a simple cooling diagram for a BEC using an R1 5VY engine in a kit car? The thermostat and housing is removed.
Mine has 2 rads....1 either side in side pods but the rads dont have caps on. Theres a pressure cap on the expansion tank though
N1
number-1
posted on 15/8/18 at 07:56 PM Reply With Quote
The reason i ask....... ive got a set up as the below picture. Is the layout correct? I ask as on my personal car, when i rev the engine the coolant level doesnt move, yet when i rev the kit car, the header tank gets an influx of fluid. Im doubting if its routed right?
Also, I cant work out what to do with the missing pieces that come from the T section that joins the top of the header tank, and goes to the water pump.....the third part which isnt drawn seems to go to the back of the engine but i cant find a drawing to explain where it goes?
Any pointers?
CosKev3
posted on 15/8/18 at 08:36 PM Reply With Quote
Hard to tell from that technical drawing
But I would put the small pipe from rad to that T piece,then the bottom pipe out of header tank needs to be joined into the pipe going into water pump
CosKev3
posted on 15/8/18 at 08:37 PM Reply With Quote
You do need flow threw the header tank,or it won't work
number-1
posted on 16/8/18 at 01:45 PM Reply With Quote
Cheers mate. yep, the picture is pretty professional isn it
I will amend the pipes when i get a day off and see how it goes.
