Author: Subject: Which bike bodies?
sdh2903
posted on 23/8/18 at 01:23 PM Reply With Quote
Which bike bodies?
I'm after some reccomendations for some bike throttle bodies.
They need to be circa 45mm diameter and individually splittable as I need 2 banks of 3.
The 955 triumph triples would be ideal but a bit small for my engine. I believe the later triples came with no injectors but had a bigger bore, is that correct?
The gsxr 1000 k1/k2 look about the best bet so far?
Any other suggestions?
40inches
posted on 23/8/18 at 01:50 PM Reply With Quote
GSXR 1300? This AJ30 has them, and is running. Look at bottom of thread
https://www.locostbuilders.co.uk/viewthread.php?tid=196422
sdh2903
posted on 23/8/18 at 06:40 PM Reply With Quote
Cheers Dave. It does look like the gsxr bodies are the way to go. I'm still torn between bodies or an inlet plenum with a single throttle
SPYDER
posted on 23/8/18 at 09:46 PM Reply With Quote
Hi there. I have GSXR750 K1 on my Toyota 3SGE engined car and a set of early GSXR1300 on the bench to go with my new engine build. I am using the Toyota "in head" injectors.
GSXR1300 are 46mm at the butterfly but taper after it to 42mm at the flange. I intend to bore out this taper as much as I can.
Unless you are aiming for 280bhp+ I would stick with the 42mm GSXR1000/750
