New Topic New Reply
Author: Subject: Sod’s law
big_wasa
posted on 30/8/18 at 07:50 PM Reply With Quote
Sod’s law
So having decided I am pulling it of the road this week end to start the winter upgrades I thought I would have one last cheeky drive to work.
On the way home I turned into a junction as the wing stay snapped and locked the front wheel up
I guess it was just a matter of time. As a silver lining maybe some carbon ones are needed but I think I will give the whole thing thing a dam good going over.
perksy
posted on 30/8/18 at 08:03 PM Reply With Quote
Bugger
See it as an upgrade potential ? Carbon is the way forward
MikeR
posted on 30/8/18 at 08:21 PM Reply With Quote
Isn't carbon lighter, therefore less stress on the mounting, therefore less likely to break and lock the wheel, therefore a necessary safety "fix" and not an un necessary upgrade?
SJ
posted on 30/8/18 at 08:35 PM Reply With Quote
Which version of the mk wing stays was it? I think the later one are tubular and less likely to break.
Mine broke 3 times in 1000 miles, they got replaced with thicker plates and bars when I fitted CF wings, been OK for 10000 miles since
SJ
big_wasa
posted on 31/8/18 at 05:23 AM Reply With Quote
The bottom halfs are tubular the tops are flat 3mm bar bent around the wheel. It's in the haz where is broken. Same place they all go. Trouble is its then grabbed the mudguard and bent the round tubing around the caliper.
SJ
posted on 31/8/18 at 06:39 AM Reply With Quote
That's same as mine. No issues so far for me fortunately. Been half expecting it though.
Bluemoon
posted on 31/8/18 at 12:48 PM Reply With Quote
Good timing would have forced you off the road after winter mods if it had hung on any longer
posted on 31/8/18 at 03:00 PM Reply With Quote
There's always Plan B
It's done a 8000+ miles on my car, with no sign of breaking. I know not everyone will like it, but I prefer practicality over fancy looks.
SJ
posted on 31/8/18 at 04:31 PM Reply With Quote
Neat solution - mine have been on for 12 years / 5k miles and still going strong though.
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
Building: finished? scratch built book locost with 1700 puma
posted on 1/9/18 at 04:54 PM Reply With Quote
Mine broke a few years ago, so, I made the replacements much stronger, 19mm drawn tubing 2.5mm wall, my mate uses it on steam engines, and 25mm x 5mm flat bar fittings and ends. They are not much heavier, but no longer vibrate, and show no signs of fatigue.
posted on 1/9/18 at 05:06 PM Reply With Quote
But can you sit on yours? I can, and have done occasionally - but carefully!
SJ
posted on 1/9/18 at 06:39 PM Reply With Quote
No, just scrape them on the garage wall occasionally.
posted on 1/9/18 at 09:13 PM Reply With Quote
[Edited on 2/9/18 by David Jenkins]
New Topic New Reply
