New Topic New Reply
Author: Subject: GRP Sheet
pekwah1
posted on 11/9/18 at 04:25 PM Reply With Quote
GRP Sheet
I'm trying to buy some black GRP sheet, only around 1mm thick or so, but need 1-2 metre lengths.
Anyone have any idea where i can get it from without paying the earth?
Thanks,
owelly
posted on 11/9/18 at 07:14 PM Reply With Quote
It's expensive to buy new so look at commercial vehicle breakers yards.....chop the side out of a Luton van.
http://www.ppcmag.co.uk
Charlie_Zetec
posted on 12/9/18 at 10:12 AM Reply With Quote
Good luck peeling GRP away from a panel on a van or commercial vehicle side! Even with redundant vehicles, assuming the laminate is still intact, the weakest substrate is usually the ply/foam/honeycomb core - so you'll never end up with a good back side. And with a thin laminate such as circa 1mm, the tearing of it will usually lead to surface cracking.
Best bet is to try and find a local (independent) panel manufacturer and see if they've got any offcuts or extra stock lying on the shelf that they'd be prepared to part with.
PS - PM sent to OP.
[Edited on 12/9/18 by Charlie_Zetec]
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
Mash
posted on 12/9/18 at 10:21 AM Reply With Quote
Roof of a luton might do it, they're usually just grp sheet
Charlie_Zetec
posted on 12/9/18 at 11:26 AM Reply With Quote
Luton roof laminate is usually 1.2-1.3mm thick, and opal coloured. Worth noting that it's composition is predominantly resin with chopped rovings (literally small strands of glass) rather than chopped strand mat (stronger). If you're happy with that, you might be able to separate it if material is bonded using adhesive tape, but if it's stuck t the roof stick with wet polyester, it won't come apart easily.
minitici
posted on 12/9/18 at 01:05 PM Reply With Quote
Laminate your own on a sheet of Aluminium (with suitable release agent of course).
posted on 12/9/18 at 02:14 PM Reply With Quote
Does it have to be GRP?
A sheet of 1.0-1.5mm thick Aluminium alloy should do the job. Be easier to cut, bend and make fixing holes in it as well.
owelly
posted on 12/9/18 at 08:58 PM Reply With Quote
I managed to harvest quite a few sheets from various vehicles. Enough to reline the inside of my ambulance, garden shed and shower-room....
Charlie_Zetec
posted on 12/9/18 at 09:29 PM Reply With Quote
Youíve done well, then! Iím assuming that it mustíve been dry freight panels with a honeycomb (or similar) core where surface adhesion area was small? A refrigerated panel (ply and foam cores) is pressed with adhesive that should never allow it to de-laminate or be pulled apart....
steve m
posted on 13/9/18 at 07:41 AM Reply With Quote
What are you building Andy ?
steve
New Topic New Reply
