Author: Subject: wanted bolt on drive shafts
chris
posted on 22/9/18 at 05:07 PM Reply With Quote
wanting to convert to discs and bolt on shafts has any one got any shafts stub axles carriers or calipers for sale sierra type
thanks
chris
[Edited on 22/9/18 by chris]
bigwill64
posted on 22/9/18 at 08:29 PM Reply With Quote
SHAFTS
ive got a set of bolt on shafts 100mm in superb condition.
chris
posted on 22/9/18 at 08:31 PM Reply With Quote
how much do you want for them
bigwill64
posted on 22/9/18 at 08:51 PM Reply With Quote
shafts
£60 +postage
Mike Bentley
posted on 23/9/18 at 03:56 PM Reply With Quote
drive shafts
Just to let you know
You can fit pop in shafts to the same diff, just remove the back cover and pull of the circlip holding the flange in and remove the flange.
You can do this if you just want to change the seals.
The pop in ones will not be as strong but will be a lot lighter, so dependent on the power of you kit car the choose is yours
I had a 919 fireblade in mine and they worked fine.
chris
posted on 25/9/18 at 12:53 PM Reply With Quote
thats drive shafts sorted any one got any hub carriers or brake calipers that they want to sell
