Author: Subject: Is this threadlock and should I apply more?
jps
posted on 23/9/18 at 04:38 PM Reply With Quote
The hub carrier bolts from my Sierra donor have blue stuff on the threads. I assume it's a threadlock. Looks like brand new Ford bolts for the same purpose have the same on them - e.g. https://www.fordpartsuk.com/rear-hub-mounting-bolt
The Haynes manual makes no mention of reapplying a threadlock when replacing the bolts on reassembly, but I thought threadlock needed reapplying once undone?
Should I buy some to reapply and if so, what stuff?
[Edited on 23/9/18 by jps]
ian locostzx9rc2
posted on 23/9/18 at 05:40 PM Reply With Quote
If your reusing the bolts clean them and reapply tread lock
tims31
posted on 23/9/18 at 06:25 PM Reply With Quote
Yes it is, its the same stuff you get when you buy new Flywheel bolts or propshaft bolts. Just clean off the old and apply new.
Halfords do small bottles of Blue threadlock which should be fine for your needs.
https://www.halfords.com/motoring/paints-body-repair/adhesive s/loctite-threadlocker
[Edited on 23/9/18 by tims31]
Build: http://www.martinsfurybuild.co.uk/
bi22le
posted on 23/9/18 at 09:48 PM Reply With Quote
And do not that it has a use by date on the bottle so don't be retiring it for important stuff many years down the line.
Please read my ring story:
Angel Acevedo
posted on 24/9/18 at 02:28 AM Reply With Quote
I did not understand that...
Do you mean it goes bad?
Or the other way around?
I have a small bottle from the start of my build.
Not used on anything critical, but I don´t remember either it has a Exp date on it.
Best regards
AA
posted on 24/9/18 at 01:01 PM Reply With Quote
Best regards
AA
I think the point he's trying to make is that thread lock has a use by date.
A quick web search shows Loctite 24 months un-opened and 12 months once opened.
Fasteners where you use thread lock are very often safety critical so to bserve the use by date!
SJ
posted on 24/9/18 at 01:56 PM Reply With Quote
That's news to me. I've still got some in the toolbox from the late 80's! [don't worry, I haven't used it]
jps
posted on 24/9/18 at 03:52 PM Reply With Quote
When I Googled it I found a *lot* of traces of people asking 'does threadlock have a shelf life' and then them getting a lot of responses like this!
Slimy38
posted on 24/9/18 at 05:14 PM Reply With Quote
Well, that's my 'learn something new every day' thing for today... my threadlock is about 3 cars old, which is close to a decade in old money.
steve m
posted on 24/9/18 at 06:00 PM Reply With Quote
If this is true, and my Loctite bottle does not have any dates on it,
My car should of fallen apart back in 1991/2
steve
bi22le
posted on 24/9/18 at 10:41 PM Reply With Quote
Hi all,
I am sorry my predictive text ruins what should be clear information. I normally check LCB in bed before sleep, often it send me to sleep!!!
Yes Locktite does have a shelf life, once it is applied it is fine though.
I use this on critical components for medical equipment and we have to prove that it is within date when applied. This is how I know.
The deterioration in performance is unknown to me but I certainly notice a difference in between the stuff I handle at work and the 10 year old stuff in my garage!!
Angel Acevedo
posted on 25/9/18 at 03:35 PM Reply With Quote
Hi all,
Ok.
That´s what I thought.
I´ll consider all of the above comments next time I buy/use.
And if you consider "Use Before Date" it may not be that expensive to buy small tubes instead of the larger bottles -cheaper per ml, as they usually last a very long time... At the end of which, you just toss the remaining and buy another.
