Author: Subject: 1/8 NPT sensot in a 1/8 BPT hole
bi22le
posted on 9/10/18 at 09:58 PM Reply With Quote
I am replacing done of my sensors as I switch to the digidash and this problem is not documented on this site, yet!
As per title. I have a 1/8 NPT from ETB and A1/8 BPT ( I think) on my Toyota engine. The guy at ETB could not offer much support but said they are so close, and tapered, then either wind it in a good few turns anyway or tap it out.
What do you guys think?
I'm going to give RAW a call tomorrow and see what they say.
Please read my ring story:
JonBowden
posted on 9/10/18 at 10:22 PM Reply With Quote
I take it that this is to go in a 4AGE we her the pressure switch normally goes?
I used one of these from eBay
https://www.ebay.co.uk/itm/BSP-NPT-Adapters-Male-BSPT-to-Female-NPT-Exten-in-Brass-European-to-American-/121411882514?var=&hash=item0
[Edited on 9/10/18 by JonBowden]
Jon
voucht
posted on 10/10/18 at 05:52 AM Reply With Quote
I think by BPT your mean BSPT, which is a BSP thread, but tapered (conical)?
No, they are not close with 1/8 NPT. One has 28 threads/inch, the other has 27 threads/inch. And diameters are quite different too.
So my advise would be that you do not fit your 1/8 NPT sender in your 1/8 BSPT hole, you will just damage both.
Try to find a male 1/8NPT to female 1/8 BSPT adapter, or a BSPT sender.
Hope that will help
Good luck!
Sylvain
http://vouchtroadster.blogspot.se/
scimjim
posted on 10/10/18 at 06:38 AM Reply With Quote
1/8 BSPT and NPT are very close (one TPI difference and about half a millimetre diameter) IF it’s a high quality piece, so it will probably fit in quite easily.
The main problem is the thread shape - NPT is 60 deg with sharp teeth, BSPT is 55 deg with rounded teeth - so it would need lots of thread sealer to have any chance of sealing.
I’d buy an adaptor
bi22le
posted on 10/10/18 at 11:54 AM Reply With Quote
The oil temp should be fine for an adapter, but I don't think I have much space for the water temp.
I could put an inline housing, if they exist, and cut a silicon tube.
Any other thoughts?
[Edited on 10/10/18 by bi22le]
Mr Whippy
posted on 10/10/18 at 12:00 PM Reply With Quote
plenty of PTFE tape...
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
Angel Acevedo
posted on 10/10/18 at 12:54 PM Reply With Quote
Do you have space for a tee?
If so, could you fit something like this:http://www.mtixtl.com/t-piecewithmale18nptandfemale18bsppfittingconnectoreq-tp-18bspp.aspx
Failing that, You could get a 1/4" X 1/8" X 1/8" Tee, modify the thread on the 1/4" branch and install the sensor on the 1/8" Branches.
HTH
Angel Acevedo
posted on 10/10/18 at 01:16 PM Reply With Quote
Incredible what you can do while doing nothing...
See what I found while waiting for the post to open...
https://acuityinstruments.com/products/bspt-to-npt-oil-cube
Not cheap though....
907
posted on 10/10/18 at 03:52 PM Reply With Quote
TIG weld (or get someone to do it ) half a nipple to half a socket.
You will then have a male to female adapter.
The one and only member of the Suttol Owners Club. Now also the MX5 Owners Club. A few more in that one.
Schrodinger
posted on 10/10/18 at 04:27 PM Reply With Quote
Is this what you need?
https://www.merlinmotorsport.co.uk/p/oil-pressure-gauge-t-piece-1-8bspt-tp-1-8bspt?utm_source=Google&utm_medium=ShoppingUK&utm_campaign=Shoppi ngUK&vat=on&currency=GBP&gclid=EAIaIQobChMIjKrQ66T83QIVAeJ3Ch1nmQqBEAQYBCABEgK0TvD_BwE
Keith
indykid
posted on 11/10/18 at 12:59 PM Reply With Quote
Ideal if you have the nipple and socket...and a tig welder (and it's undoubtedly what I'd do) but for £3.80 posted, I'd be sorely tempted to go for the brass one!
Good way to make a 90/135° adaptor though...
[Edited on 11/10/18 by indykid]
me? ambivalent? well, yes and no
stevebubs
posted on 11/10/18 at 03:30 PM Reply With Quote
For plumbing, Think is generally my first stop..
https://www.thinkauto.com/acatalog/On_line_shop_Various_178.html
stevebubs
posted on 11/10/18 at 03:31 PM Reply With Quote
MFS10-3-3 should do the job, I think - worth calling to ask
stevebubs
posted on 11/10/18 at 03:34 PM Reply With Quote
also https://www.amazon.co.uk/dp/B01JZX6H9U/ref=psdc_1939465031_t1_B00FXSSUH4
