Author: Subject: Wanted! Sierra front caliper brackets - for non ABS/240mm discs
jps
posted on 13/10/18 at 02:11 PM Reply With Quote
As per title - I have a new set of calipers with the 54mm piston (which i believe is for the 240mm discs) - but only brackets from calipers with the 60mm piston (for the 260 discs)...
[Edited on 13/10/18 by jps]
mcerd1
posted on 15/10/18 at 07:57 AM Reply With Quote
If your stuck I think I've still got a spare pair of 60mm calipers (in need of recon)
jps
posted on 15/10/18 at 09:08 AM Reply With Quote
Cheers - I have a set of the 60mm needing refurb myself.
And I have a donor on the drive with the full 10mm, unvented, style caliper setup too...
But the 54mm type I have are still in their boxes from the supplier - fully refurbed and good to go!!
