DANMAN
posted on 20/10/18 at 11:05 AM |
Fuel line size?
Hi everyone,
I am using a stock 2005 CBR1000 fuel pump in my fuel tank which then runs through a new 6mm ID fuel line and new filter to the 1000 engine but am
having an odd issue where if the engine is idling and I give it a quick stab to 6000rpm it runs rough on its return to idle and then misfires if
trying to accelerate again. If I let the idle settle down I can repeat the above, it seems like it is having a fuel supply issue (it also runs like
crap if I try driving it as well like it is almost out of fuel). Fuel pressure checks out ok as does fuel flow according to the CBR1000 workshop
manual.
What size fuel line have others used and is the factory pump ok for a BEC scenario?
Daily Driver - Audi A4 2L Turbo Quattro
Work Horse - Falcon XR8 Ute - Now Supercharged!
Rally Beast - 1972 Ford Escort 2L
Off The Road - Locost 2L Turbo (Z1 Concept)
Track Car - Stuart Taylor Blade
Angel Acevedo
posted on 20/10/18 at 04:07 PM |
Based on age I suppose you are running Throttle bodies, if so, most likely a overrun fueling map problem.
6 mm seems OK as thats what my mustang has as standard and good for 215 HP. (maybe even slightly smaller)
HTH.
