Author: Subject: Help identifying radiator
number-1
posted on 26/10/18 at 05:55 PM Reply With Quote
I know this will be a tough one to crack....but....... can anyone tell me what this radiator is from?
Its 280mm x 275mm x 50mm. The inlet/outlets are for 25mm cooling pipes. It only has a bleed nipple on top and no filler cap. Its heavy so presume its from an older car.
Myke 2463
posted on 27/10/18 at 08:32 AM Reply With Quote
Could contact them and ask..Address: Stonepit Rd, South Cave, Brough HU15 2RF
Phone: 07802 766128
Be Lucky Mike.
number-1
posted on 27/10/18 at 11:52 AM Reply With Quote
Every time ive contacted them, they cant really help me out as when the current owner purchased Roadrunner racing they started on the 7 style car and had no dealings with the SR1 single seater
posted on 27/10/18 at 01:25 PM Reply With Quote
It looks as if the corners of your rad are very square unlike any rad I've seen , it may be a one off? I would take your rad to your local radiator specialist and see what they say?
posted on 19/11/18 at 06:31 PM Reply With Quote
What do you mean by older car?
Radiators from older cars had radiator caps. What you have looks like it's been modified, the right angle brackets don't look standard.
Why do you need to know, there have been many hundreds of different radiators made over the years, so bound to be something that you could use.
number-1
posted on 21/11/18 at 12:33 AM Reply With Quote
Yeah i initially thought it was bespoke for the car but the top right angle brackets dont get used at all. Id have thought if it was bespoke then the additional brackets wouldn't be there
As for the older car part.....somewhere in the deepest part of my brain i recall seeing something like a Triumph, or MG with a similar rad but google has drawn a blank
The reason im asking is to see if theres a cheap option to replace them for something newer and lighter.
