<<  1    2  >>
Author: Subject: silly mistake :-(
craigdiver
posted on 28/10/18 at 11:23 AM Reply With Quote
silly mistake :-(
I hate making mistakes but have found that my upper anchorages are only 400mm above the reference point not 450mm as required by IVA section 31, requirement 16. Going to have to rework my roll hoop and have it powder coated again. Silly mistake - annoyed at myself :-(
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
Daf
posted on 28/10/18 at 11:41 AM Reply With Quote
Have you got any scope to lower the seat at all?
craigdiver
posted on 28/10/18 at 11:48 AM Reply With Quote
did look at that but seat is only 50mm off the floor (25mm runners + 25mm subframe).
shouldn’t be too big a job to rework rear hoop, just a pain having to pay to get it powder coated again - entirely my fault. Rear hoop was fabricated while car was in bits
mccsp
posted on 28/10/18 at 12:11 PM Reply With Quote
On the positive side, at least it bolts in and out!
Why do it the easy way, when I can do things my way!
craigdiver
posted on 28/10/18 at 12:16 PM Reply With Quote
I think ill have to knock up a brace which will be exact size of mounting holes as likely once the welds are ground down and rewelded in position it could open or close the roll hoop spacing.
Toys2
posted on 28/10/18 at 02:24 PM Reply With Quote
Could you fit inserts to have the eyelets vertical so they are at the top of the tube?
In fact I've never seen them as you currently have them, is that allowed anyway?
craigdiver
posted on 28/10/18 at 02:45 PM Reply With Quote
Eye bolts should never have the loading at over 45 degrees from centre, this will cause excessive shear forces on the eye, I would be surprised if having the load at 90 degrees (shearing load) would be allowed. However, in saying that I suspect the forces created, even in an impact, are a fraction of the rated loading of the shouldered eyebolt.
sdh2903
posted on 28/10/18 at 03:17 PM Reply With Quote
Every westfield has them vertically.
craigdiver
posted on 28/10/18 at 04:37 PM Reply With Quote
cars must be different from the real world, you wouldn’t be allowed to lift a load using eye bolts at that angle due to the shear forces. Would be interested to hear from an opinion from an automotive engineer.
steve m
posted on 28/10/18 at 05:25 PM Reply With Quote
Think I would be moving the eye bolt up, and the seat down first, and take it for the test as it is,
If it fails, do something about it, if it pass's then jobs a goodun
As there are only a very very few who have passed first time
steve
sdh2903
posted on 28/10/18 at 05:29 PM Reply With Quote
In fact every kit car ive seen has them vertically.
They are well over engineered any way. Even in a 10g accident they are only going to have to restrain what say a ton of force ? and there's 4 per person.
How have you mounted your lower eye bolts through the floor vertically to keep them in the correct plane?
craigdiver
posted on 28/10/18 at 05:30 PM Reply With Quote
steve
I like your thinking, seats cannot be lowered, any ideas how to raise the eyebolt 50mm - I could bolt a very sturdy bracket to the existing eyebolt bush tube and bolt the eyebolt to the top of the bracket? anybody seen anything like this?
craigdiver
posted on 28/10/18 at 05:38 PM Reply With Quote
very good point, my lower mounts are loading up at 90 degrees as the upper ones would be if they were vertical
Toys2
posted on 28/10/18 at 06:01 PM Reply With Quote
So would this be an option?
Not my photo and obviously your fixings would be on top of the bar
craigdiver
posted on 28/10/18 at 06:14 PM Reply With Quote
maybe some extension pieces like this, would only need to be 50mm tall
Kevin
posted on 28/10/18 at 06:51 PM Reply With Quote
My car failed first time with seats that look like yours. The reason was that the back of the seat was not high enough. I know that the head rest will raise but was told that you could only have up to 25mm gap between the top of the seat and the bottom of the head rest. Please double check this as I was nervous on the day and might have got this wrong.
craigdiver
posted on 28/10/18 at 07:01 PM Reply With Quote
this is getting worse by the minute, going to raise the bar with the seatbelt anchorages 100mm and take my chance with the seats :-(
jps
posted on 28/10/18 at 07:22 PM Reply With Quote
Weld in the new one before you cut out the old one?
craigdiver
posted on 28/10/18 at 07:25 PM Reply With Quote
It will be the same one, just moved, was costly to get the 7/16” threaded bushes made in a custom length. Spoken to my mate (professional welder who originally welded it up and does not see a problem grinding down the welds and re-welding 100mm higher)
melly-g
posted on 28/10/18 at 08:04 PM Reply With Quote
If they're baby cub seats take the base pad off.
Would that make a difference? Just put a pad on the base instead.
I think I only had a piece of carpet on mine for the test!
craigdiver
posted on 28/10/18 at 08:08 PM Reply With Quote
Genius idea, that would fix it, the thick (6”+) seat pad does move and appears to be fixed in be material at the front but would be worth cutting it to remove it and replace with thin foam pad, this would sort anchorages height and possible seat back height.
gremlin1234
posted on 28/10/18 at 08:30 PM Reply With Quote
seat pad / seat base
technical term is seat squab, ( but don't confuse it with young pigeons! )
craigdiver
posted on 28/10/18 at 08:32 PM Reply With Quote
haha, that made me laugh :-)
pmc_3
posted on 28/10/18 at 09:16 PM Reply With Quote
Could you make up some spacers to fit under the roll bar mounts and raise the roll bar instead of moving the harness fixings?
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
craigdiver
posted on 28/10/18 at 09:19 PM Reply With Quote
going to remove the seat squabs, they are at least 6” thick so will also fix any seatback not being tall enough issues, but thank you for the suggestion
<<  1    2  >>
