Author: Subject: 10,000uF capacitor advice
Charlie C
posted on 8/11/18 at 08:15 AM Reply With Quote
Hi
I need a 10,000uF capacitor for my COP 12v supply, not being electrically experienced I don’t know what I’m looking for or where I should be looking. I would like a capacitor which I don’t have to solder in to place and it would be handy if it has spade connectors.
Can anyone recommend a capacitor and where to buy one from online.
Charlie
Slimy38
posted on 8/11/18 at 09:31 AM Reply With Quote
Normally I'd say Maplin, but A) they're gone, and B) they would be expensive! Either Farnell or RS would sell them.
I can see RS do ones with screw terminals but the price is significantly higher than the standard solder in ones. Spade terminals are normally reserved for much bigger capacitors, 1F and suchlike. That's mainly due to the physical size I guess?
posted on 8/11/18 at 10:07 AM Reply With Quote
Excuse any ignorance on my part here, but COP I'm assuming is Coil On Plug?
Speaking to our electronics engineer here at work he suggested RS Components as a source for these. You can buy from RS as a private individual as well.
Our engineer did highlight that such capacitors aren't cheap. The Kemet brand ones he showed me online were £20 each.
He also mentioned it's important to understand the datasheet information for them. Furthermore some of them run hot and are therefore vented so should be mounted with the vent unobstructed to avoid damage to the capacitor.
Alternatively (if it is Coil On Plug) does the original vehicle manufacturer not sell a suitable component?
Charlie C
posted on 8/11/18 at 10:19 AM Reply With Quote
Hi
Yes Coil Over Plug
These are going on an MX5 engine which is controlled by a Magasquirt MS3 with MS3X card, the MK1 mx5 didn’t have COP’s so there is no mazda mx5 standard part.
posted on 8/11/18 at 11:36 AM Reply With Quote
Originally posted by Charlie C
Hi
Yes Coil Over Plug
Understood and thanks for the clarification.
Slimy38
posted on 8/11/18 at 12:57 PM Reply With Quote
Hi
Yes Coil Over Plug
You're right there isn't an mx5 part, but I'm 99% sure there is another make that is a common fit for the engine. Have a look on YouTube at some of the big turbo builds or similar, i think you'll find something suitable.
posted on 8/11/18 at 02:58 PM Reply With Quote
Another good supplier is Rapid. Note: I tried to put a link to the exact page for these capacitors, but the site's mechanism broke it. Here's the full line - cut-and-paste it:
https://www.rapidonline.com/Catalogue/Search?Query=capacitor&Tier=Electrolytic%20Capacitors&Attributes={%22Capacitance%22:[%2210mF%22]}
Don't forget that you probably don't want a 12V rating - you will want a good safety margin over that to allow for the way the "12V supply" varies in a car, often up to more than 15V in normal conditions. There are often transient voltage spikes well over that. Maybe a 35V one will do the job, but please take advice. Of course, if this is in a 5V part of the electronics, or the instructions specifically state 12V, then 12V is fine!
Also, I don't know how warm this capacitor will get in an engine compartment; it may be necessary to get one with a higher temperature limit than normal (it's a common requirement, so won't add a lot to the price).
[Edited on 8/11/18 by David Jenkins]
posted on 9/11/18 at 10:57 AM Reply With Quote
Not being familiar with such things as COP do you need a capacitor per plug or will a single capacitor work across multiple plugs?
Charlie C
posted on 9/11/18 at 11:11 AM Reply With Quote
From what I've read its 1 capacitor per 4 cops, i dont know if thats a rule of thumb or what the facts behind that is.
SPYDER
posted on 9/11/18 at 11:24 AM Reply With Quote
Hi Charlie! I run two wire ex-Hayabusa COPs in my car with no caps on the supply other than a small suppressor.
It's a good idea to fit "clip-on" ferrite rings to the supply for extra noise rejection.
Is the cap recommended by the COP manufacturer Charlie?
Charlie C
posted on 9/11/18 at 01:45 PM Reply With Quote
Hi
The capacitor is recomended by the megasquirt provider and the chap who will be mapping the engine, also there are lots of threads on miata and Mx5 websites which also recomend using a capacitor. My engine is from an mx5 with a turbo added i dont know what differance that makes but the general advice has been the same.
posted on 9/11/18 at 02:48 PM Reply With Quote
Whats the capacity of an old points type condenser, would one of those be any good?
SPYDER
posted on 9/11/18 at 08:45 PM Reply With Quote
Points condenser is typically less than half of a microfarad. He needs ten thousand!
I have a low value cap across the supply of my cops to act as a noise suppressor.
The OP needs one to act more as a power reserve/smoothing device I suspect.
