Author: Subject: Afternoon!
Guinness
posted on 17/11/18 at 02:52 PM Reply With Quote
Afternoon!
After a break of too many years, I'll be starting to hang around here again.
Long story short, after several years of agency work, short term contracts, and more than a couple of periods of under employment, I'm now in a FT job. We've made another small human, and our eldest is now a bike mechanic.
I've sold the daily driver, and managed to get the Pug back on the road, and almost standard., so there was a bit of space in the yard.
The increadibly patient and generous DaveK has looked after the Indy for the last 8 years, and today has delivered her back to us!
First impressions are, I still need a pair of rear arches and lights, she'll need a complete fluid change, and a battery, but generally doesn't look too bad.
Anyway, a bit of work over the winter, and hopefully back on the road by Easter!
M
posted on 17/11/18 at 04:46 PM Reply With Quote
Welcome back!
MikeR
posted on 17/11/18 at 08:50 PM Reply With Quote
Congratulations and welcome back
posted on 19/11/18 at 09:41 AM Reply With Quote
Ditto - life events can certainly get in the way of car building activities, but it sounds like you're back and ready to continue
Guinness
posted on 27/6/20 at 01:09 PM Reply With Quote
Wow, another two years seems to have slipped by.
Anyway, a combination of a global pandemic, lockdown and a short period on furlough meant I finally had time to work on the Indy.
So far, I've stripped the back end down, from the bulkhead behind the seats to the fuel tank, removed all the flaking powdercoat and rust, and then re-painted the chassis, bones and rebuilt the suspension. Fitted new rear arches and got the back end back on the ground.
Front end is up in the air now, with the wishbones, headlight bar, hubs, mudguard stays and steering rack and column stripped, de-rusted and primed and painted.
Just about to start to drain down the coolant systems to get the radiator and oil cooler off, so I can clean the rust and flaking powder coat off the chassis forward of the engine.
Plenty to be getting on with, but looking for advise on a decent paint system for the chassis. I can't get it blasted, as the bodywork is still fitted, and to be honest the experience of the original powder coat hasn't been great. Looking for recommendations for brush applied primer and satin chassis black. Thinking the Frost own brand?
Anyway, hope there's still knowledgeable people around here (as I think I've decided to swap the big Zed engine out and replace with a MX-5 drivetrain).
posted on 27/6/20 at 05:14 PM Reply With Quote
I wouldn't fret about build time if I were you - mine took over 6 years, and others on this forum have taken far longer. My chassis alone took over 3 of those years, until I got to the point where I said "either I finish it, or it goes". So I finished it!
MikeR
posted on 28/6/20 at 08:36 AM Reply With Quote
I keep looking at chassis painting as it's a big job I've got to do. The problem at home is cleaning the metal, using a flap disk/wire brush in a drill grinder polishes the metal smooth, giving little to grip. Blasting leaves a rough surface so better paint grip. I'm wondering if the solution is clean, etch, then paint. The best paint seems to be A 2 pack epoxy.
Guinness
posted on 14/8/20 at 08:12 PM Reply With Quote
Time for a quick update;
Completed the front end wire brush and repaint, and reassembled the front end.
(Has anyone got a torque figure for the front hub mushroom adapter pinch bolts?)
Dashboard, scuttle and bulkhead have all been removed, along with all the wiring.
Cooling system has been drained and radiator / oil cooler removed.
An MX5 engine, gearbox, clocks and loom has arrived from a low mileage clean 1.8VVT donor and I think I've sourced a set of indicator / wiper stalks, steering lock, ignition barrel and matching key / immobiliser / ECU.
Fingers crossed that'll allow me to strip out the last of the sierra switch gear and go for a single donor electrical system. Just got to work out if I can fit that lot to a Sierra steering column, or whether I need to replace the top part of the column with an MX5 part.
The car has gone over to a mate's workshop to get the engine out, cut the chassis mounts off and weld up some new engine mounts.
New radiator and fan has arrived, just need to sort a coolant overflow bottle.
Just a few bits left to sort out;
Thinking about using the MX5 fuel pump / sender so I'll have a working fuel gauge (for the first time ever!).
(Does anyone have the dimensions of the top, oval plate, of a standard MX5 fuel tank thing, so I can see if it'll fit in the top of the tank).
Oh, and speaking of other firsts, I've bought a reverse light. Quite looking forward to not having to get out and push anymore!
Final thing, is I'm aiming to fit a windscreen and heater, so I'm looking for inspiration about how to package everything on the scuttle. Grateful for links to photos of neat installs of heaters, wipers, washer bottles and batteries!
Mike
jps
posted on 15/8/20 at 06:14 AM Reply With Quote
I am planning on the same as the spec when it was originally fitted in the Sierra.
I understand others have failed IVA because they did not have a secondary fixing, so the hub/mushroom needs drilling and tapping and a bolt fitting too.
SteveWalker
posted on 15/8/20 at 02:19 PM Reply With Quote
I've heard of that too, but always wondered why, when there is no secondary fixing when the upright is clamped to the end of a McPherson strut and it's still exactly the same clamping mechanism? Is there something I'm missing?
Incidentally mine went through (SVA) with no problem.
40inches
posted on 15/8/20 at 04:31 PM Reply With Quote
The sierra strut has a rib that is trapped in the clamp
http://www.fordopedia.org/parts-catalog/sierra-mk1/B2.10
SteveWalker
posted on 15/8/20 at 06:14 PM Reply With Quote
That could be it! But do all other types?
kj
posted on 27/7/23 at 07:53 AM Reply With Quote
Hi Mike how's the car coming along?
Think about it, think about it again and then do it.
