Author: Subject: Gearbox options?
wonderfulweasel
posted on 24/12/18 at 10:41 AM Reply With Quote
Gearbox options?
I was hoping to fit an RX8 gearbox to my Stylus (it has a bigger than usual tunnel from the previous install), but I've measured up and it's not going to go in.
It looks like it'll be going down the typical Type 9 route, but wondered if there were any other (budget) options out there that I've missed?
It'll be going onto either a Zetec or crossflow, so standard bellhousing pattern.
big_wasa
posted on 24/12/18 at 12:51 PM Reply With Quote
Is that a 6 speed ? The five looks a little smaller.
Retro ford do a nice looking mk3 mx5 conversion.
There is a guy that uses the mk1+2 mx5 box with a home made adapter . If you can make an adapter it wouldn't get any cheaper.
After that it's T9 or Mt75. Neither are cheap now.
wonderfulweasel
posted on 24/12/18 at 01:37 PM Reply With Quote
Yeah, it was the 6 speed I was looking at. I'll take a look at the ratios on the 5.
Thanks for the heads up on the Retro Ford option. I'll take a look, it sounds interesting.
big_wasa
posted on 24/12/18 at 01:51 PM Reply With Quote
If you find the ratios can you post them up.
And the mx5 box looks tiny.
kingster996
posted on 24/12/18 at 03:55 PM Reply With Quote
Gear ratios on here https://www.miata.net/garage/KnowYourCar/S8_Gears.html
I used to be indecisive, but now I'm not so sure
