Author: Subject: BEC Oil Cooler
jamiepearson69
posted on 17/1/19 at 09:58 PM Reply With Quote
BEC Oil Cooler
Hi All
Just in the process off fitting an Oil cooler to my Fireblade BEC and I wondered what the difference was between a standard duty Mocal Unit and a Heavy Duty unit.
Will the standard dut unit do the job, or should I go heavy duty?
snapper
posted on 17/1/19 at 10:36 PM Reply With Quote
I don’t like the description standard and heavy duty, in oil cooler terms it’s about the area of the cooler.
Width and rows, I.e. 300mm x 13 row.
If your running a bike engine then the one that came with the bike is a good start.
Ducting cold air through the cooler increases the performance, letting the hot air out of the engine bay is essential.
Go for s known make Mocal or Setrab, use an oil thermostat.
Look at cooling as a whole, water, oil, heat in the engine bay, wrapping exhausts, heat shielding, letting the hot engine bay air out faster than it cane in.
I eat to survive
I drink to forget
adithorp
posted on 17/1/19 at 10:46 PM Reply With Quote
I was told me a couple of years ago the standard Mocal ones are made in the far east (China?) and the HD ones are made in GB (or EU).
http://jpsc.org.uk/forum/
snapper
posted on 17/1/19 at 10:48 PM Reply With Quote
Adding to my earlier post
I had a braided hose clamped with jubilee clips blow off luckily I shut off and saved the engine, the replacement hoses wher swaged on black hydraulic hoses with appropriate threaded ends to fit oil cooler and thermostatic takeoff plate.
I eat to survive
I drink to forget
