bikecarbfred
posted on 11/2/19 at 04:01 PM |
Ignition Fuse keeps popping
Took engine in and out a few times. Ignition fuse keeps popping now on "ON" position (no cranking)
Wire diagram below. As Fuse F4 keeps popping instantly, is it safe to say anything that I have marked red could be the problem?
I have removed every singly accessory fuse including lamba sensor, fuel pump etc. Fuse still pops instantly.
Severe short circuit.
gremlin1234
posted on 11/2/19 at 04:27 PM |
it won't be the HT side of things, -distributor, sensor, or plugs, (30, 32 & 31)
it wouldn't be the brown wire earthing the amp either.
I would put a bulb across the fuse terminals, (test with a 5W 12V bulb first)
then I would disconnect the ignition amp, see if it still draws such a high current.
my guess would be a short in the fuse box itself.
bikecarbfred
posted on 11/2/19 at 04:41 PM |
On the HT side of things
28, 29, 30, 31 & 32 are not being used as im running bike carbs with stand alone ECU megajolt.
Angel Acevedo
posted on 11/2/19 at 04:43 PM |
Unplug Everything no fuse and check continuity to ground at all points.
Any short will show readily as continuity to ground.
bikecarbfred
posted on 11/2/19 at 04:47 PM |
Angel,
so volt meter set to continuity. and one lead on ground points and other lead on where? Fuse box points?
And if i hear buzzing noise then theirs problem?
Does ignition switch obviously need to be turned on for this testing?
gremlin1234
posted on 11/2/19 at 04:49 PM |
if you are not using the above items, then
the circuit doesn't do anything. have you perhaps terminated a random black wire to chassis? like you would on a lucas loom?
Angel Acevedo
posted on 11/2/19 at 05:12 PM |
Angel,
Yes, If there´s a short in any cable run you´ll hear buzzing.
quote: Originally posted by bikecarbfredAnd if i hear buzzing noise then theirs problem?
As stated by gremlin123, even if you have everything but you don´t have 28, then you don´t need that fuse/cable unless you are planning for future
upgrading.
You may terminate at the switch, remove the fuse or terminate after the fusebox. Terminating after the fusebox with a short cable properly insulated
at the end may allow for future changes or using as spare circuit.
Angel Acevedo
posted on 11/2/19 at 05:15 PM |
....have you perhaps terminated a random black wire to chassis? like you would on a lucas loom?
Being marked Sw = Schwarz (Black) this must be the culprit.
[Edited on 2/11/2019 by Angel Acevedo]
bikecarbfred
posted on 11/2/19 at 07:38 PM |
if on connector 28 , if all three wires were cut and taped up together, that would 100% cause a short circuit to blow fuse number 4?
wylliezx9r
posted on 11/2/19 at 07:43 PM |
Yes it would. Tape them up individually or use terminal blocks.
[Edited on 11/2/19 by wylliezx9r]
George Best
bikecarbfred
posted on 11/2/19 at 07:48 PM |
i didnt do any multimeter testing. just saw those three wires loosly taped with electrical tape.
i undid the tape and noticed the were all touching each other.
not sure how the car drove for last two years.
i might have squeezed the tape in last few weeks while doing engine work causing the wires to touch even more.
anyway no fuse popping now.
gremlin1234
posted on 11/2/19 at 09:40 PM |
yes
100%,
but they didn't do a good job of joining them in the first place, if only now does it blow fuses.
I don't know if you should tie connector 28-2 Gn/Ro (green/red) high or low, but from looking at the circuit, I think best to leave it
'floating'
edit: it would have worked for the last 2 years, because the circuit doesn't do anything, Why did you check the fuse and then find it
blowing?
edit2: well done for finding that!
edit3: remove fuse 4 it doesn't do anything, then it should all play nicely ;-) but do terminate the other end or the sw (black) wire cleanly
too
[Edited on 11/2/19 by gremlin1234]
bikecarbfred
posted on 12/2/19 at 06:50 AM |
gremlin, i can't remove fuse 4.
i need it for megajolt and edis coil because it's the only slot that stays live when cranking i believe so the sparks plugs can fire when
cranking which is crucial.
