New Topic New Reply
Author: Subject: Mounting Engine
MDR1987
posted on 20/2/19 at 12:59 PM Reply With Quote
Mounting Engine
Sorry if there is a post already on this, but looking to mount a Zetec SE in a striker - does anyone have any tips/tricks on height etc?
any pics or comments gratefully received!
many thanks
Matt
big_wasa
posted on 20/2/19 at 07:21 PM Reply With Quote
Although I’ve not mounted a Se rwd I’ve done other engines.
Set the car level on some hard standing. Use bits of wood under the wheels to get the car sitting straight and level.
Plonk the engine and gearbox in the hole. Again get the engine level and in the position you want using more wood.
It wants to be as close to the bonnet as you can get.
I aim for a gap of 15mm all around. Ie you want a little room for it to move on the mounts. It will settle a little so it really needs to be as high as you can get it with out touching.
With the engine plates on the engine and rubbers it’s a case of cutting the tubes.
You want 6mm min for the plates and 3mm 40mm tube or box to join them together.
Cheers warren
Ugg10
posted on 20/2/19 at 07:54 PM Reply With Quote
This is how I mounted one in my anglia but could be modified for locost style.
Mounted on ac pump bolts and steering pump mounts at front of engine. The end of the arms bolt onto land rover bobbins and these then bolt onto the chassis. Only issue with the design is that the mount covers the holiness in the block where the crank alignment tool goes in when changing the cam belt so mount needs to be removed to do this.
[url=https://flic.kr/p/qZKT6K]
[url=https://flic.kr/p/qniR6M]
[url=https://flic.kr/p/qn6qfj]
[url=https://flic.kr/p/riYrXD]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
MDR1987
posted on 20/2/19 at 08:05 PM Reply With Quote
Brilliant stuff - many thanks!
Ugg10
posted on 20/2/19 at 08:38 PM Reply With Quote
If you trawl through this link there are pictures of various mounts. They are in classic cars but can be adapted. I got inspiration from the blue escort. Worth noting the square tube on mine goes right through the main plate and is welded both sides. It was then flanged to give a bit more strength.
http://www.turbosport.co.uk/showthread.php?t=145051&page=7
The Zetec se is a stock fit on Caterham and Westfield so they may have someth8ng off the shelf (at a price).
https://caterhamparts.co.uk/186-engine-mounts
[Edited on 20/2/19 by Ugg10]
melly-g
posted on 21/2/19 at 08:25 PM Reply With Quote
They are a very tall engine, I swapped my pinto for one and it's a lot taller!
The sump hangs really low and the top of the engine is almost touching the bonnet.
The Avon is maybe quite low at the front bodywork?
[Edited on 21/2/19 by melly-g]
Ugg10
posted on 21/2/19 at 08:49 PM Reply With Quote
I have a stock 1.7 and will have a 1.6 in the garage next week if you need dimensions. Just let me know what.
[Edited on 21/2/19 by Ugg10]
New Topic New Reply
