<<  1    2    3    4    5  >>
Author: Subject: Jag V6 dyno results (at last)
CosKev3
posted on 3/3/19 at 09:47 PM Reply With Quote
Originally posted by theduck
Boost control is a pwm output and different to the “programmable” outputs.
Ah right,thanks
40inches
posted on 24/3/19 at 01:43 PM Reply With Quote
Just got back from having the VVT set up.
272bhp after 2 hours on the dyno.
The photo upload has stopped working again So will post the Dyno graphs when I find
a suitable hosting site.
pigeondave
posted on 24/3/19 at 01:50 PM Reply With Quote
shiver me timbers
you must be happy with that.
How many torques.
40inches
posted on 24/3/19 at 02:02 PM Reply With Quote
Originally posted by pigeondave
shiver me timbers
How many torques.
Around 250 starting at over 200 at 2000rpm.
With the VVT set up as Jaguar from the factory, we got the rated 240bhp, it looks like
Jaguar neutered the engine, possibly for emissions????
pigeondave
posted on 24/3/19 at 02:27 PM Reply With Quote
And I trust you'l bee winding it back a little for the same reasons
Out of interest what box and diff are you using?
CosKev3
posted on 24/3/19 at 03:58 PM Reply With Quote
Wow
So what was your setting on the VVT to get that power?
40inches
posted on 24/3/19 at 04:00 PM Reply With Quote
The standard Getrag S-Type box with Sierra 3.38 diff.
Photos in my archive https://www.locostbuilders.co.uk/photos.php?action=gal&user=40inches&folder=AJ30
40inches
posted on 24/3/19 at 04:08 PM Reply With Quote
Wow
I think on at 1800rpm with 60% TPS and off at 5800RPM.
Strangely the Jag setting is on at 5200rpm, according to one of the Jag manuals, and that
gives 240bhp as per the specs.
The engine had been mapped at the standard settings, but needed a lot more fuel added at the optimum settings.
CosKev3
posted on 24/3/19 at 06:03 PM Reply With Quote
Wow
Really good to know that the ST200 inlet hasn't restricted the engine!
How much more fuel could the standard injectors put in?
I've bought a set of 6 hole mustang injectors for mine,picked them up for what it would cost to get the originals refurbed so thought give them a go.
40inches
posted on 24/3/19 at 06:30 PM Reply With Quote
Wow
Not sure, will have a look at the settings, I think they are on about 85% duty cycle. They are around 240cc/min
BaileyPerformance
posted on 25/3/19 at 04:36 PM Reply With Quote
What did your car make at the wheels?
r1_pete
posted on 26/3/19 at 12:37 PM Reply With Quote
Looks like a great result Dave, its really tempting to go for a similar setup in my Scimitar....
big_wasa
posted on 26/3/19 at 04:53 PM Reply With Quote
If your not in a rush Pete I may be selling mine in a few weeks. I just want to make some brum brum noises first.
r1_pete
posted on 26/3/19 at 07:38 PM Reply With Quote
No Rush Warren, it’ll be a long parts gather, hiding the total cost from swmbo
[Edited on 26/3/19 by r1_pete]
big_wasa
posted on 26/3/19 at 08:47 PM Reply With Quote
Yeh just the silicone hoses are making me wince this month.
40inches
posted on 16/4/19 at 07:58 AM Reply With Quote
Trying to find a photo hosting site that will embed the photo in a post.
This is the best I can do at the moment https://btcloud.bt.com/web/app/share/invite/uanmtLGpRY
Partofthechaos
posted on 16/4/19 at 04:37 PM Reply With Quote
That is seriously impressive output for an off the shelf engine, especially one normally used to lug an executive car up and down motorways. 90bhp/L without anything more than an engine map!
The problem is this is making me excited to get mine built, but I'm doing the kit car thing in reverse. Currently dismantling my second donor, so starting off with a car and ending up with a kit.
big_wasa
posted on 17/4/19 at 11:52 AM Reply With Quote
I keep looking at it and think how the hel does it fit in the hole
40inches
posted on 17/4/19 at 12:49 PM Reply With Quote
Only just, I had to fit a SAAB idler pulley to clear the chassis. There is 20mm clearance at the cam covers.
Doing it again I would fit an electric water pump, so no need for idler pulleys.
CosKev3
posted on 17/4/19 at 05:09 PM Reply With Quote
Once the engine is stripped of unwanted parts it's pretty small tbh,I can drag mine around the garage with ease
CosKev3
posted on 17/4/19 at 05:13 PM Reply With Quote
Yeah I've gone for EWP,never used one before but like the sound of how the controller works,faster warm up from cold is a bonus,the controller just pulses the pump at set intervals until the coolant is nearly at your target temperature set in controller.
With these engines having a remote thermostat the EWP set up makes the pipework set up much easier and neater too.
CosKev3
Incase anybody comes across this thread in future and is interested in the weight of the engine heres some idea:
Bare engine with just small Denso alt fitted=120kg.
As above with ST200 upper inlet manifold and ST200 solid flywheel =132kg.
As above with RX8 6 speed gearbox and Mondeo 240mm clutch=181kg.
[Edited on 17/4/19 by CosKev3]
big_wasa
posted on 17/4/19 at 05:49 PM Reply With Quote
On the St220 the water pump is driven from a pulley on the back of the head and is prety compact. But that means more plumbing like a Zetec.
I did test fit the adapter plate last week end. One of the locating dowls is in a differant place.
I hope to get started on the wiring loom Easter Monday as the wife is working
[Edited on 17/4/19 by big_wasa]
CosKev3
posted on 17/4/19 at 06:01 PM Reply With Quote
Who's plate have you bought?
big_wasa
posted on 17/4/19 at 06:14 PM Reply With Quote
One of Jonathan Hughes Aj30 to Rx8 plates.
<<  1    2    3    4    5  >>
