<<  1    2    3    4    5    6  >>
Author: Subject: Jag V6 dyno results (at last)
RWD Focus
posted on 19/4/19 at 03:25 PM Reply With Quote
What is the direction of rotation of the AJ30 engine? Just asking for a mate who has just rung and asked me.
CosKev3
posted on 19/4/19 at 08:44 PM Reply With Quote
Originally posted by big_wasa
One of Jonathan Hughes Aj30 to Rx8 plates.
Strange,that's who mine is off and it fits straight on.
big_wasa
posted on 19/4/19 at 09:15 PM Reply With Quote
Isn’t yours a jag lump ? Mines a Ford.
There are two holes for the dowl. The jag must use one and the ford another.
I will get a photo.
CosKev3
posted on 19/4/19 at 09:56 PM Reply With Quote
I will get a photo.
Ah yeah,forgot you were using a FWD V6
CosKev3
posted on 11/6/19 at 08:07 AM Reply With Quote
Well mines up and running
Big thanks to Dave(40inches) for his help and knowledge on this engine on here and via email
Mapped yesterday by Dale @Bailey Performance and the results were awesome!
286bhp,254bhp at the wheels
https://youtu.be/cR57ENgqC_M
Wet roads on the drive home meant I didn't use more than half throttle, and it was still very fast
BaileyPerformance
posted on 11/6/19 at 09:39 AM Reply With Quote
I look a bit miserable in the video, i should be smiling we power like that out of a stock engine!
[Edited on 11/6/19 by BaileyPerformance]
CosKev3
posted on 11/6/19 at 09:44 AM Reply With Quote
Cheers for yesterday,totally different car now!
Fired up lovely cold too this morn
BaileyPerformance
posted on 11/6/19 at 09:49 AM Reply With Quote
My pleasure, very nice install, a treat to work on.
CosKev3
posted on 11/6/19 at 09:55 AM Reply With Quote
Just dug out that air temp sensor
40inches
posted on 11/6/19 at 10:48 AM Reply With Quote
Brilliant Kev
What RPM was peak power at?
Doesn't seem worth the effort fitting ITB's!
CosKev3
posted on 11/6/19 at 11:09 AM Reply With Quote
Originally posted by 40inches
Brilliant Kev
I didn't take a pic of the graph,and Dale's printer wasn't working!
If Dale sees this he has it saved on the PC
Pretty sure the graph was still climbing at the 7100rpm limiter.
I did mention to Dale I had read of people running them to over 8000rpm,but he wasn't keen!!!!
40inches
posted on 11/6/19 at 11:36 AM Reply With Quote
The limiter was set at 7200rpm on mine and was still climbing
[img][/img]
CosKev3
posted on 11/6/19 at 02:29 PM Reply With Quote
big_wasa
posted on 11/6/19 at 04:22 PM Reply With Quote
That’s a great result.
Any chance of some engine bay shots now the photo uploader is working ?
I would love to see what this engine could make with some long primary headers and throttle bodies. I just don't know how you would get them in a 7.
[Edited on 11/6/19 by big_wasa]
CosKev3
posted on 11/6/19 at 04:27 PM Reply With Quote
Dale's currently mapping a Lambo that was in the Fast and Furious 8 that is running a AJ30 in it now,that's got some long primary manifolds on it as it has plenty of space in the back of a Lambo!
It's also running cams and some high comp pistons,but still on the standard AJ30 inlet manifold.
The steering column is the biggest issue in a seven type car to make a decent manifold fit on drivers side.
Throttle bodies would require a massive bonnet bulge,or a big cut out with a massive filter sat outside the bonnet.
[Edited on 11/6/19 by CosKev3]
RWD Focus
posted on 11/6/19 at 04:30 PM Reply With Quote
Thats amazing power if mine is near that i will be very happy
CosKev3
posted on 11/6/19 at 04:32 PM Reply With Quote
Photo uploader still wont allow pics off my phone
'Sorry! is an unnsuported file type. Please email ChrisW if you believe it should be'
big_wasa
posted on 11/6/19 at 04:37 PM Reply With Quote
You have to re size them first.
I already have the exhaust manifolds but there going to be more suited to a Gt style car.
sdh2903
posted on 11/6/19 at 04:45 PM Reply With Quote
Rocketeer have ran jenveys and their own inlets on the dyno and the jenveys were down on power. I reckon I could fit itbs under my scoop but after seeing the results on a standard engine I'm not sure it's worth it. After seeing Dave's and kevs results on the st200 manifold I'm kind of a bit annoyed I didn't go that route. I always thought it just looked a bit restrictive obviously not!
RWD Focus
posted on 11/6/19 at 04:53 PM Reply With Quote
Ive got a couple of st200 manifolds but mine needs the throttle body at the front as the rear is too close to my bulkhead in my focus, i did consider chopping one up and moving throttle body to other end.
big_wasa
posted on 11/6/19 at 05:30 PM Reply With Quote
The Rocketeer tbs where on very short inlets with sock filters that are well known to rob power.
I am surprised how the st200 mani performs. Given the restrictions here and the exhaust 300bhp can’t be far off.
I guess the question I really want to know is what it drives and handles like ?
sdh2903
posted on 11/6/19 at 06:16 PM Reply With Quote
You maybe interested in selling one?
If using the st200 setup do you need both upper and lower manifolds? Or do you mate the upper to the jag lower?
RWD Focus
posted on 11/6/19 at 06:46 PM Reply With Quote
You mate the two together if i remember correctly. A member on here showed me how he had done his. Im gonna hang onto them just for now incase i need to cut more than one up to make it suit my application. There was one on eBay i think.
RWD Focus
posted on 11/6/19 at 06:53 PM Reply With Quote
Ignore that last message, ive just had a look in my other unit and found another st200 inlet complete. So if you want one give me a shout. Its upper with throttle body, lower, injectors and fuel rail. Can post if need be.
CosKev3
posted on 11/6/19 at 09:06 PM Reply With Quote
I've used plastic AJ30 lower inlet manifold,then chopped up a ST220 alloy lower inlet manifold to make up the 15mm spacer required to fill the gap between the AJ30 lower inlet and the ST200 upper inlet.
Had to weld some tabs onto the sides of the spacer and drill and tap them for the ST200 upper mounting points.
<<  1    2    3    4    5    6  >>
