furryeggs
posted on 28/2/19 at 07:50 PM |
Have i blown my oil pressure gauge?
I've just got my dash back together after re trimmimg it and have noticed my oil pressure gauge isn't working. Everything was fine and ok
before the re trim. The back light is fine and I have checked the voltage and connections to the sender and it's all testing ok...
I did however stupidly get the signal and voltage wires mixed, is this likely to of fried my gauge. oil pressire light is ok, (on with ignition and
off when running)... Is there anything else to check just incase? before i give Stack more of my money...
Mr Whippy
posted on 1/3/19 at 07:25 AM |
what's the signal voltage? I once connected a fuel gauge direct without the regulator and it blew instantly, they tend to be quite fragile due
to the fine wires used for the needle coils
[Edited on 1/3/19 by Mr Whippy]
furryeggs
posted on 1/3/19 at 09:02 AM |
7v with ignition on, 5v running. tested at gauge and sender.
furryeggs
posted on 4/3/19 at 09:39 PM |
Been through the wiring again to check and all chevks out ok. I think it mst be buggered
James
posted on 6/3/19 at 01:06 AM |
Probably worth asking the manufacturer if they'll look at repairing it before you replace.
Also, any decent electronics engineer can probably work out what's blown and may be able to replace the failed component.
- Muhammad Ali
