Author: Subject: Repairing aluminium casting
cliftyhanger
posted on 5/3/19 at 11:04 AM Reply With Quote
I have a "bit" of gear linkage housing (old Triumph gearbox) that has broken. Made of cast ali, so I can't mig it.
Has anybody tried the Lumiweld/aluminium brazing rods that are sold? Experiences would be very welcome.
The part is not massively stressed, but does get the occasional whack if a gear change is aggressive. So it is not just a a cosmetic repair required.
And I have seen epoxy resins/putties that claim to be "stronger than the base metal" but again, anybody got experience?
TIA
Clive
posted on 5/3/19 at 11:19 AM Reply With Quote
Probably better to find someone to TIG weld it, maybe cheaper as well?
Mr Whippy
posted on 5/3/19 at 12:12 PM Reply With Quote
I've used the aluminium brazing rods before and you need a lot of heat to get them going and very clean metal, they do work but the balance between soft and pliable to running all over the place is tricky. It hardens very quickly so crystals tend to be big and the part brittle. Used JB weld a lot too and it's good for repairing cracks, hose fittings etc but not for what you are talking about
I think I'd opt for getting it tig welded.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
JAG
posted on 5/3/19 at 12:26 PM Reply With Quote
I've used Technoweld for Aluminium brazing. It works but does need a lot of heat as the Aluminium parts conduct the heat away from the joint.
Anything with any mass, say thicker than 3mm or so, will be hard to get hot enough and keep hot enough; unless you have a suitable Oven!
I'd get someone local to TIG weld it for you
[Edited on 5/3/19 by JAG]
Justin
theconrodkid
posted on 5/3/19 at 02:24 PM Reply With Quote
https://www.mig-welding.co.uk/
have a word on ^^^, should be someone local that would tig it for you
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
gremlin1234
posted on 5/3/19 at 04:41 PM Reply With Quote
I assume its the gearbox top cover/extention
https://rimmerbros.com/Item--i-GRID005689
if so the top is relatively flat, and you may be able to bolt on an external reinforcement
cliftyhanger
posted on 5/3/19 at 05:53 PM Reply With Quote
It is sadly the rarer, and very tricky to find, overdrive later gearbox. Last linkage I saw was over 100 (for the linkage) so I don't think I will get lucky.
As I suspected, the magic fixes don't work. I have a lead on a local TIG welder, will get in touch.
Thanks all.
James
posted on 5/3/19 at 11:42 PM Reply With Quote
At Mclaren they use Devcon for repairing all sorts of bits of tools and equipment.
I would certainly consider using it for something like this.
View User's Profile View All Posts By User U2U Member   James 's Aim
fazerruss
posted on 6/3/19 at 01:30 PM Reply With Quote
These are the kind of jobs I do in my spare time (TIG). I'm.not local though so it would need to be posted to me.
Do you have any photos of the damage?
http://www.mig-welding.co.uk/forum/threads/motorcycle-crank-case-repair.85103/
[Edited on 6/3/19 by fazerruss]
"if assholes could fly this place would be an airport"
View User's Profile View All Posts By User U2U Member   fazerruss 's Yahoo
