Author: Subject: Rebuild or put it together and hope for the best
gav2612
posted on 6/3/19 at 01:49 PM Reply With Quote
Hi all, been a long time since I was last on here. I was doing an engine swap on a Sylva striker a few years back from xflow to duratec. Unfortunately I got as far as having everything fitted together and plumbed, but never got as far as installing the omex and firing the engine. Selling our house and garage where my car was forced selling it in its state at the time. Fast forward 6 months and I bought myself a ready built and running rotrex 4age powered raw striker and have been enjoying it for weekend and fast road blasts for the last 18 months with nothing other than servicing and tinkering to keep it running sweet. It’s a fairly recently refreshed 4age 20v silvertop running at a very moderate boost level and producing 210bhp and 150lbft. While it’s more power than I’ll ever need on the road, on a track it could do with more. Most things on the car are set up ready for more power, heavy duty type 9, clutch and diff and bigger front brakes. All I’ll need is bigger injectors, different Rotrex pulley and a mapping session for over 250bhp 😊. The 20v 4age is a high compression engine however and probably won’t take much more boost reliably. With that in mind, I’ve sourced a supposed 70,000km 4agze engine which uses the same block as the 4age and will bolt straight up to the 20v head. The 4agze being supercharged is slightly lower compression and has semi forged pistons and is know to easily take 300hp out of the box.
Now at last my question. The engine has been lying around in the persons garage I bought it from for quite some time. I did a quick leakdown test on it and the results were around 20% on a couple of cylinders, however it sounded like that was all escaping from the inlet valves which had the odd rust spot on them. I’m about to pull the cylinder head and do a very basic check on the state of the bores. If these look and measure ok, what’s the opinion on just bolting the silvertop cylinder head up and hoping for the best? I’m trying to avoid a full bottom end rebuild, but if people think it’d be advisable im capable enough of changing out the main and big end bearings. Obviously if the bores are damaged or out of shape I’ll be looking at a hone or re bore and new rings at which point I’d get the bottom end fully rebuilt anyway
Angel Acevedo
posted on 6/3/19 at 02:01 PM Reply With Quote
Even if journals dont show wear signs, I´d check them, and once you are there, fit new bearings.
If it happens that there are visible uneven wear, yo have to do it anyway if you will be running high power...
ian locostzx9rc2
posted on 6/3/19 at 04:06 PM Reply With Quote
I can’t see the point in not checking the bottom end you will have the engine in bits anyway
gav2612
posted on 6/3/19 at 04:27 PM Reply With Quote
Thanks for the comments. I’ve got a set of calipers so will take your advice and drop the sump and measure and check the condition of the journals before I go any further. all being well I’ll replace the bearings before proceeding.
perksy
posted on 6/3/19 at 04:32 PM Reply With Quote
As above
I'd drop the sump and check the big end and main bearings
Having a look inside the sump will give you an idea of what sort of life its had
It'd be a shame to only go so far with the checks and then it turns around and bites you when your on a track day ?
