Author: Subject: Type 9 input shaft length change
Paul TVR
posted on 10/3/19 at 09:45 PM Reply With Quote
Is it possible to change the input shaft on the type 9 from short to long? it would appear the issue I had with nasty noises from the clutch is down to the input shaft being shorter than it should be. The caterham bellhousing for the c20xe to type 9 is 170mm long, I believe this would suit a long input shaft.
Is it possible to change them? Can anyone recommend a good company to speak too? The other option is to change the bell housing but will mean altering the clutch position, the gearbox mounts and the gear lever position will move forward as well.
flak monkey
posted on 11/3/19 at 06:13 AM Reply With Quote
Yes it's possible to change them if you strip the box down.
Sera
http://www.motosera.com
mcerd1
posted on 11/3/19 at 08:55 AM Reply With Quote
if you don't want to do it yourself then try BGH:
http://www.bghgeartech.co.uk/html/bgh_home.html
or maybe Road & Race Transmissions (lot of folk on here have used them, although I've not dealt with them myself)
and I sure there are a few more places
Paul TVR
posted on 30/4/19 at 12:45 PM Reply With Quote
BGH were etremely helpful, supplied parts and advice to change the input shaft, seems to be working now!
