Author: Subject: stamping engine number
belgian2b
posted on 31/3/19 at 10:19 AM Reply With Quote
Hello,
the Pinto engine in my Westfield SEW ha no engine number.
I am on the way to register the car here in Belgium and it will go through a test more complicated then MOT but not as IVA.
So , it would be better to have the engine number.
This engine number is on the V5 ( car comes from UK to belgium)
Problem: how can i stamp the engine number without taking engine out ?
What would you recommend ?
Gerardo
posted on 31/3/19 at 10:35 AM Reply With Quote
Try cleaning the area where the engine number should be before
stamping, it may show the original up. Use some fine emery cloth
belgian2b
posted on 31/3/19 at 03:28 PM Reply With Quote
Area has been checked, no number
big_wasa
posted on 31/3/19 at 07:44 PM Reply With Quote
You won’t stamp it in the car.
obfripper
posted on 31/3/19 at 09:52 PM Reply With Quote
You could try one of these:
https://www.ebay.co.uk/i tm/38-PCS-Automatic-Punches-Alphabet-Numbers-Metal-Letter-Tool-Punch-Stamp-Set-3-MM/264131340785
The similar auto dot punches are effective and for the price are worth a try, if nothing else you will have a set of letter punches.
Dave
ianhurley20
posted on 31/3/19 at 10:12 PM Reply With Quote
Stamp an engine number! Sorry - that is the role of car thieves and ringers - and if it does not have one you have to ask why!!!!!!!?
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
SteveWalker
posted on 1/4/19 at 08:24 AM Reply With Quote
If the engine was replaced at any time, it would likely have been supplied with no number. They often are.
jps
posted on 1/4/19 at 11:05 AM Reply With Quote
I've heard this too somewhere. I would assume that it could be etched in with a die grinder type tool - but would be a pain to do I think!
SteveWalker
posted on 1/4/19 at 11:17 AM Reply With Quote
ISTR that the intention with replacement, new engines is that they should be stamped with the number of the old engine before installation and the old block should be scrapped or the number ground off. More important these days, where the engine number often matches the VIN and you'd not want a warranty replacement with a mis-matched number that could raise questions when you come to sell.
Mr Whippy
posted on 1/4/19 at 11:44 AM Reply With Quote
I bought a recon engine from Ford and there was no number on the engine
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
sdh2903
posted on 1/4/19 at 11:50 AM Reply With Quote
Not remotely true.
All new Ford crate engines for example don't come with engine numbers stamped. Same with new bike engines too. So would be the same if the donor car had a new engine at any point.
