Author: Subject: Seized twin choke Weber carb
pmc_3
posted on 1/5/19 at 08:36 PM Reply With Quote
After some advice please chaps. I've got a 32/36 DGAV twin choke Weber carb that i'd like to use on a project. It's in pretty good nick, linkages are all good, the choke flaps are present and move freely, the primary throttle butterfly moves fine but the secondary throttle butterfly is seized solid. I've tried spraying it with WD40, put some penetrating oil on it, left it to soak in some old petrol for several hours but it still won't budge. I managed to get the screws out that hold the butterfly to the spindle but that hasn't helped.
Any suggestions on what to try next?
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
Angel Acevedo
posted on 1/5/19 at 10:54 PM Reply With Quote
Ultrasonic cleansing?
cliftyhanger
posted on 2/5/19 at 06:08 AM Reply With Quote
Are the ends of the spindle accessible? If so light tap with a hammer/flat ended punch may help.
Heat is always good, hot air gun should be about right.
It may need an extended soak in a penetrating solution. Old petrol not the best idea. But a mixture of ATK and acetone is apparently "the best" otherwise WD40, plenty of it over an extended period.
If all else fails, I assume new spindles are available? and butterflies? The last resort is to cut the spindle, knock it out and fit new.
mark chandler
posted on 2/5/19 at 06:42 AM Reply With Quote
Stick it in a small saucepan with some diesel and cook it for a few minutes
Benzine
posted on 2/5/19 at 06:55 AM Reply With Quote
Hot oil is king. Engine oil, veg oil, I've unstuck so many things using it. (take care, obviously)
steve m
posted on 2/5/19 at 07:26 AM Reply With Quote
Are you saying the top butterflies are stuck? as that's part of the choke system, and don't actually need to work on our cars
as a couple of pumps on the throttle and start the engine will do the same thing
I reckon the butterfly bar has been glued in place to stop it closing itself on deacceleration
steve
posted on 2/5/19 at 09:57 AM Reply With Quote
The OP said the choke flaps are free. WD40 isn’t a penetrating oil , better to use something like Plusgas giving the seized part then maybe heating with a hot air gun then gently attempting to move the butterfly.
pmc_3
posted on 3/5/19 at 09:07 PM Reply With Quote
steve
Nope just one of the bottom butterflies. The one that opens first is fine but the second that opens with more throttle is seized.
Thanks for the advice guys, i'll try a bit of heat from the heat gun and report back.
