Author: Subject: Coil Over Bracket Supplier
BigDawgV8
posted on 7/6/19 at 05:50 AM Reply With Quote
Morning All,
Looking for a couple of lower coil over brackets.
I thought that I had seen them for sale somewhere a while back......
Basically a three sided piece of thick steel box section with a 12mm hole through both sides to support the shock.
Hoping someone can help.
Thanks!
posted on 7/6/19 at 07:37 AM Reply With Quote
Can you not make them?
Get a short length of box section steel, cut short lengths from it then drill the Ø12mm holes across it, cut one of the faces off and you've got your U shaped bracket.
BigDawgV8
posted on 7/6/19 at 08:19 AM Reply With Quote
Thanks!
Yes, have done that before.
Just seeing if available ‘off the shelf’ first.
40inches
posted on 7/6/19 at 08:48 AM Reply With Quote
If you don't mind paying! eBay Item
tweek
posted on 7/6/19 at 08:58 AM Reply With Quote
https://www.demon-tweeks.com/uk/allstar-performance-coil-over-brackets-245662/
Hope that helps...
"oh dear..." said god,
"I hadn't thought of that"
and promptly vanishes in a puff of logic
jps
posted on 7/6/19 at 11:16 AM Reply With Quote
I've got a few kicking about in my garage - let me know what dimensions you need. You've got Suffolk in your location - whereabouts are you?
Slimy38
posted on 7/6/19 at 12:53 PM Reply With Quote
I got mine from Dave at Rogue Engineering;
https://www.ebay.co.uk/usr/daveo1121
Looks like he still has them for sale, and he can do bespoke ones if you need something slightly different. He posts them out very quickly and they're good quality.
