Author: Subject: R1 5PW Gear shift indicator
Squadge
posted on 14/7/19 at 06:44 PM Reply With Quote
Hi all,
has anyone used these gear indicators? do they work well? is there any sensor on the 5PW that says what gear it is actually in?
https://www.amazon.co.uk/Motorcycle-Indicator-Xvs950A-Midnight-Xv1900a/dp/B07MY572D1/ref=sr_1_fkmr1_2?keywords=r1+5pw+gear+indicator&qid=156312950 0&s=gateway&sr=8-2-fkmr1
Thanks in advance
adithorp
posted on 14/7/19 at 07:27 PM Reply With Quote
Got a HealTech one, of which this looks like a copy. Works ok and easy enough to fit. Picks up neutral switch feed plus revs and speed. There's a programming procedure (going through the gears with the wheels off the ground) and it calculates gear from revs/speed.
http://jpsc.org.uk/forum/
Squadge
posted on 14/7/19 at 09:28 PM Reply With Quote
Ace, thanks for the reply.
adithorp
posted on 15/7/19 at 07:31 AM Reply With Quote
Due to the way they calculate the gear, they won't give you a true reading if you change gear when stopped (except for neutral) or when coasting up to a junction with the clutch in.
Squadge
posted on 15/7/19 at 07:51 AM Reply With Quote
Ok, that's fine, just after something that gives me an idea as this bike shift style is going to get some getting used to.
