Author: Subject: Which starter motor to use
Ing bkerkhof
posted on 10/8/19 at 06:02 AM Reply With Quote
Good day,
I just bought my first westfield se with a crossflow engine. Love it just there is of course a lot of work and improvements to make.the first issue i ran into was the starter. The relais is facing downward which makes this the lowest part of the car. Really not good because one of the mounting points has already a crack in it.
Can someone tell me a part number for the starter with the relais facing upwards? It is a ford crossflow engine with 5 speed trans. Car is made in 1997.
I found one ford cortina starter whith the relais facing upward but i am not sure if this fits.
Thank you!
posted on 10/8/19 at 07:18 AM Reply With Quote
Can’t help with a part number but a little bit more information might help such as which side of the engine is the starter fitted, which bell housing , how many bolts secure the starter to the bell housing( presumably 3?) lastly how many teeth are on the flywheel ring gear as the xflow engine used at least 2 ? Can you also get any numbers off of your present starter which might help ? Is the car LHD? Starterman may be along with a bit more help ?
starterman
posted on 10/8/19 at 06:20 PM Reply With Quote
Part number or pictures would ideally be needed.
Mike
Ing bkerkhof
posted on 10/8/19 at 06:53 PM Reply With Quote
I will give the current part number after the weekend. First some cooling liquid for myself...
Thank you!
Boxster 3.4 roaf legal tracktoy
Maserati 3200 gt
Bmw z3 m54 turbo (in progress)
Ing bkerkhof
posted on 12/8/19 at 10:21 AM Reply With Quote
The part which is on my car now is the 0 001 208 718
Also written 87 gb 11000 ba. it has 11teeth.
Does this help?
Maserati 3200 gt
