Author: Subject: Brake Reseviour Pipe Size
the_big_1
posted on 13/8/19 at 06:32 PM Reply With Quote
Hi guys,
Do you think there will be an issue using the standard brake pipe for the connection between the reservoir and master cylinder or is it to small?
JAG
posted on 14/8/19 at 08:15 AM Reply With Quote
Standard brake pipe will be fine - unless you have ABS/SCS etc... on the car.
The flow from the brake reservoir into the Master cylinder is very small unless the car has ABS/SCS etc...
On a simple brake system the flow simply compensates for brake pad wear.
Justin
the_big_1
posted on 14/8/19 at 08:43 PM Reply With Quote
Perfect, thought so.
Many thanks for your help!
