Bluemoon
posted on 27/8/19 at 02:35 PM |
Garage/Workshop photos
Looking to build a new garage/workshop. Anyone fancy posting some inspirational photos of internal setup?
Dan
posted on 27/8/19 at 02:52 PM |
Sadly my garage has been converted to a bedroom
Tips I can give though....
1. Wire in plenty of mains sockets around the garage/workshop
2. Wire in plenty of mains sockets at a decent height where your workbench will be
3. Wire in plenty of lights (good light is a real pleasure to work in)
4. Paint the walls white so they reflect lost of the good light around for you
5. Fit draft excluders to any doors/windows - keeping the space comfy for winter working makes a real difference
6. Plan your storage and shelves so tools are stored well and easy to find and put away - tidiness is good
Ugg10
posted on 27/8/19 at 03:40 PM |
To the above I'd add - make sure any benches are the right height for you - I made mine quite high (approx. 1m) so I am working at chest height
and so don't have to bend over (kitchen tops are 0.7m iirc). Also, old filing cabinets are good for storage and the A4 paper multiple draws good
for nuts and bolts. I also went for side hinge doors as I find them easier, don't rob roof storage space, low maintenance and if you want you
can put a board across the top when open to give you and extra 3ft of covered workspace.
Pictures of my garage posted on here - http://locostbuilders.co.uk/viewthread.php?tid=215429
[Edited on 27/8/19 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Bluemoon
posted on 27/8/19 at 03:45 PM |
Ugg10, thanks for the post, that's what got me thinking! How did you recess the scissor lift? Which one did you go for?
Nice neat and practical setup!
Dan
[Edited on 27/8/19 by Bluemoon]
posted on 27/8/19 at 03:46 PM |
A 2nd for filing cabinets - ideal for storage.
Another add would be if you're a cyclist think about bike storage. You can get pulley systems to store them up higher (out the way). It frees
up floor space and save the bike from getting dragged about.
posted on 27/8/19 at 04:16 PM |
Insulation if your going to be working in cold weather and also ventilation. LED lights are so much better than tubes . A nice thick strong concrete
base that’s level and smooth
Ugg10
posted on 27/8/19 at 05:55 PM |
Nice neat and practical setup!b
Dan
Info on the linked thread, had my garage rebuilt so could get the builders to concrete a recess to the right size. I think the built the shuttering
around the lift then used this to build the inset. The base is 8” of reinforced concrete as per the spec sheet for the lift.
I linked this lift as it has no cross members so good for removing gearboxes and exhausts.
I also have led strip lights from TLC iirc, great light, put in as many as you can, they are only about 20w each. I didn’t do it but a power socket in
the ceiling or on the central rafter would be useful for inspection lights.
I’ve also promised myself I will plumb in my compressor with three or four wall points one day.
steve m
posted on 27/8/19 at 07:01 PM |
Lighting, is at the very top, as bad lighting will keep you away from the garage
plenty of wall socket, both sides
extension cables,
tools kept in a tidy manor
You have to make it, as though you want to be out there at -8 in the winter, when its dark at 1600,
andyou don't actually need any heat
so I have, I have and sky tv, and a good stereo
steve
posted on 28/8/19 at 02:51 PM |
Another vote here for a good stereo as well!
I moved one into my garage and was lucky enough that my WiFi reached out there. Meant I could stream Spotify via my phone and listen to all sorts
while tinkering about with nuts, bolts, rivets etc.
