Author: Subject: Open drive sockets
Slimy38
posted on 23/9/19 at 12:51 PM Reply With Quote
Open drive sockets
Leading from the battery impact wrench thread, I went on to Lidl to have a nosey. While I don't need an impact wrench for now, I did see these;
https://www.lidl.co.uk/en/p/car-essentials/powerfix-profi-3-in-1-spanner-with-socket-set/p25474
I've always wanted a 'through drive' type socket set as I frequently find the nut or bolt bottoms out in the standard socket. Has anyone got some of these types of socket, are they as good/useful as they seem?
For a set of ten sockets and a wrench it seems like a no-brainer, unless someone can suggest a better alternative?
coyoteboy
posted on 23/9/19 at 01:18 PM Reply With Quote
I've been using some Crescent X6's. They appear to be fine on perfect heads, but as soon as you get a slight hint of corrosion or rounding they're awful. I do mean awful. Like worse than cheapie 12 point sockets.
[Edited on 23/9/19 by coyoteboy]
Report your local potholes, it actually works!
matt5964
posted on 23/9/19 at 02:15 PM Reply With Quote
For rounded fasteners we do our KENgrip range that are ok for up to 95% rounded heads
https://www.cromwell.co.uk/shop?query=Kengrip
As for pass through sockets we also do a set and individually
https://www.cromwell.co.uk/shop/hand-tools/quatro-go-thru/go-thru™-sockets-for-ratchet-combination-spanner-set/f/6216?query=Push%20through%20Spanner r />
https://www.cromwell.co.uk/shop/hand-tools/spanner-sets/10-19mm-ratchet-spanner-and-socket-set-23pc/p/KEN5823980K
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
SJ
posted on 23/9/19 at 04:54 PM Reply With Quote
I got some Cromwell sockets years ago - still going strong. I'm generally a fan of Lidl tools but they aren't in the same league as Cromwell.
Slimy38
posted on 23/9/19 at 05:20 PM Reply With Quote
I am a huge fan of Cromwell tools, in fact if you ever take first born children as part payment I would be more than happy to do a deal...
...unfortunately my daughter will be glad to hear that my budget is very much in the Lidl zone.
ken555
posted on 23/9/19 at 10:19 PM Reply With Quote
Be aware that because of the outside drive the hole up the middle can be smaller than the bolt size sometime!
So for instance the 17mm socket, does not have a 10mm hole, therefore it still bottoms out .
You would have to check these ones, but I bought a set of thru drive in a previous Lidl/Aldi special and discovered the problem
posted on 24/9/19 at 11:54 AM Reply With Quote
I have a set of Gearwrench pass through sockets which have been invaluable for some jobs, though they don't get a lot of use. A worthy investment though, and I found the Laser branded system is compatible when I needed a longer extension.
I also have a socket set with that 12 point spline drive system that I keep in the car, simply because they fit hex, 12 point and and E-Torx heads, so ideal for minimising the amount of stuff in a small tool kit. They seem to be adequate from the limited use I've given them, though not something I would choose for everyday use.
