Author: Subject: Type 9 thrust bearing
se7ensport
posted on 24/9/19 at 08:53 PM Reply With Quote
Simple initial question, with a cable clutch is the thrust bearing supposed to touch the clutch plate fingers all the time and therefore rotate with the engine, or is it supposed to sit a number of mm away from the fingers when the clutch is not pressed.
posted on 25/9/19 at 06:54 AM Reply With Quote
Adjust the cable so that the clutch pedal has a small amount of play, approx 19mm ,before it starts to compress the clutch .Another way is to adjust the cable so there is 2 to3 mm play on the clutch arm where the cable attaches
snapper
posted on 25/9/19 at 09:07 PM Reply With Quote
Thrust bearing touches the fingers, the play described is simple take up of clutch pedal movement and some cable flex
I eat to survive
I drink to forget
se7ensport
posted on 25/9/19 at 11:11 PM Reply With Quote
So the thrust bearing spins at the same speed as the engine rotates.
