number-1
posted on 5/10/19 at 02:32 PM |
Tube bending help.....
Can anyone point me in the right direction to get a bit of tube bent for between a supercharger and an intake plenum? Its not an off the shelf
dimension and needs to be in metal
76mm OD tube with 2mm thick walls (can be 3 if easier?), legs can be 15cm long but no longer, however, this is where it gets tricky as i need it to be
7cm from the top of the bottom leg, to the bottom of the top leg...if that makes any sense??? I will get a picture uploaded to make it clearer.
Anyone got any ideas? I cant weld so making something isnt an option and silicone hose isnt suitable.
N1
[Edited on 5/10/19 by number-1]
posted on 5/10/19 at 02:49 PM |
Don't know about tube bending, but it looks a pretty tight bend to me. Might be something you need fabricated for you from 2 or more sections.
number-1
posted on 5/10/19 at 02:52 PM |
Hello mate,
Yeah thats what i thought too. Maybe x2 90 degree elbows cut down and left with 3.5cm on each joining leg?
Its probably a simple thing to do if i knew how to weld
posted on 5/10/19 at 03:33 PM |
It seems like something an exhaust fabricator could make for you in stainless steel tube.
mark chandler
posted on 5/10/19 at 03:57 PM |
That,s a really tight radius, tube bender is the person to call
https://tube-bender.co.uk
He will tell you what's possible, if he cannot get it that close you will need to get a bent section off him as close as possible and then have
someone slice it and weld it to tighten up.
40inches
The tightest bends I have seen are 1.5 the tube diameter.
LINK
J666AYP
posted on 5/10/19 at 04:23 PM |
With a radius that tight I would get two 90's and weld them.
rf900rush
posted on 5/10/19 at 06:51 PM |
May be worth trying to look for donuts
may not be the correct size but may help the search
eBay Item
https://www.ebay.co.uk/itm/INTERCOOLER-PIPE-MANDREL-BEND-Mild-Steel-3-5-360-DEGREE-DONUT-SEAMED/223062979897?hash=item33ef96f539:g:arAAAOSw9-ldkEVS
gremlin1234
posted on 5/10/19 at 07:20 PM |
I think the original pic is somewhat confusing,
it mixes cm and mm as units and seems to draw it much tighter than required
a slightly closer to scale, without mixed units might be
Simon
posted on 5/10/19 at 07:39 PM |
Two of these
https://www.allstainlessltd.co.uk/nominal-bore-fittings/nominal-bore-schedule-10-90-deg-weld-elbow-to-ansi-b16.9-316
or
https://www.allstainlessltd.co.uk/nominal-bore-fittings/nominal-bore-schedule-40-90-deg-weld-elbow-to-ansi-b16.9-316
or
https://www.allstainlessltd.co.uk/mandrel-bends-and-tube-for-exhaust/hygienic-90-deg-bend-316-to-bs4825-part-2-1D-polished
welded together
[Edited on 5/10/19 by Simon]
coyoteboy
posted on 5/10/19 at 11:53 PM |
99% sure that's too tight to bend. Maybe a cast part might work, welded together.
Report your local potholes, it actually works!
Angel Acevedo
posted on 6/10/19 at 05:14 PM |
I´d go for Pie-Cutting from appropriate material and sending to welding shop.
As a lot of the labor goes into cutting, dressing and fitting, cost may be reduced substantially...
HTH.
WallerZero
posted on 7/10/19 at 06:14 AM |
You need an 73mm centreline radius (to hit your 7cm (70mm?? Don't mix units lol). If you find some place that can do that, and not break the
bank of a hobby project, let me know, it would probably get me a promotion at work! Haha. Basically its not a normal bend radius so would need
specific tooling to do = ££££.
Best option imo would be 2x 90 degree bends and some fabrication work to achieve your part
[Edited on 7/10/19 by WallerZero]
http://zachsgbszero.blogspot.co.uk/
pewe
posted on 7/10/19 at 05:29 PM |
Try Rich's Fabrication Shop in Abingdon on faceache.
He seems an all round top welder and does lots of one-offs.
HTH.
#Cheers, Pewe10
907
posted on 7/10/19 at 08:09 PM |
quote: Originally posted by Simon
Two of these
or
or
welded together
2 off of the 3rd one down, cut the straight bits off (+3mm) and weld together.
Paul G
motorcycle_mayhem
posted on 7/10/19 at 08:30 PM |
I fabricated mine from 'Donuts'.
Available from most outlets, e.g. Merlin where I bought mine (I have no connection).
You might be able to bodge a silicone hose onto a half-cut donut, but not something I'd even try (I weld things).
Camber Dave
posted on 8/10/19 at 07:44 AM |
For something that tight, I would make a hardwood former and form it as two sides from flat sheet.
Though at 2mm it will need to be annealed so oxy-acetylene or propane will be needed.
Even so it could be difficult to weld in the middle.
