Author: Subject: Sticky caliper. Repair or buy new?
SJ
posted on 10/10/19 at 11:42 AM Reply With Quote
Is it worth the cost saving of stripping sticky calipers to clean and replace seals? Looks like refurb ones are about 40.
These are standard Sierra single pot calipers 1.8 cvh model.
Stu
big_wasa
posted on 10/10/19 at 11:50 AM Reply With Quote
By the time you have bought pistons, seals and sliders ect I wouldn't bother if they are that cheap.
posted on 10/10/19 at 01:42 PM Reply With Quote
When building my MK Indy I opted to source recon front brake calipers rather than use 15 year old tatty ones from the donor car. I'd go for recon ones at that price and save yourself the time and effort of rebuilding them yourself.
voucht
posted on 10/10/19 at 03:55 PM Reply With Quote
You don't need to buy a lot of things to renovate your calipers.
When I renovated mines (they were in a bad shape when I got them out from the Sierra) I just bought new piston seals and new slider sockets. Costed me 24 all in all (for both)
Put brake-fluid resistant grease on the sliders, pistons, piston seals and piston cylinder in the caliper body.
Calipers have worked like a charm since.
hope that will help
Sylvain
https://vouchtroadster.blogspot.com/
https://cafrazx550.blogspot.com/
SJ
posted on 10/10/19 at 04:21 PM Reply With Quote
Thanks.
The current calipers were new when the car was built in 2006.
Maybe I'll pull the old one apart first and assess the state it is in. It actually isn't even rusty but is pretty well stuck.
ian locostzx9rc2
posted on 10/10/19 at 05:07 PM Reply With Quote
If there 40 each I would buy recon ones which are checked cleaned and pressure tested for piece of mind it is brakes after all
posted on 11/10/19 at 09:47 AM Reply With Quote
Ditto - my thinking as well - brakes are vital, get them right!
SJ
posted on 11/10/19 at 09:48 AM Reply With Quote
Just ordered a pair for 85 delivered.
Seems like the easiest option.
Stu
