lewis
posted on 13/11/19 at 09:17 PM |
Cylinder head gas flowing
I have a ST 170 head that I want to get gas flowed (polished & ported) can anyone recommend a company to carry this out? I’m in West Sussex.
I am a driving god!..........sort of
ttalps2000
posted on 14/11/19 at 08:04 AM |
Dunnell Engines?
Schrodinger
posted on 14/11/19 at 08:20 AM |
you could also try Scholar Engines http://www.scholarengines.co.uk/
both Scholar and Dunnell are in/near Stowmarket Suffolk.
Keith
pigeondave
posted on 14/11/19 at 01:46 PM |
Have a look round the Ditchling area (could be the industrial estate)
I'm sure that there was someone local.
Other wise I'd say Dunnell, but its a trek.
Is there no-one in Guildford area?
posted on 14/11/19 at 01:54 PM |
Vulcan engineering , just off the M20 specialise in Ford engine and heads
procomp
posted on 14/11/19 at 01:55 PM |
Having just had an ST170 engine in for quick check over that had received head work by a company listed above, Id simply say just deal with CNC
heads.
couldn't fault there work on a customers engine i rebuilt last month.
Dick
posted on 14/11/19 at 03:07 PM |
Neil Roper you wont get better and hes not as expensive as you may think. Lot oh engine builders use his heads
obfripper
posted on 14/11/19 at 08:28 PM |
Get hold of A.L Developments, he did a good job on my zetec head, it was 2-3 weeks turnaround, he also fitted a set of valve guides and ported/matched
the inlet to the head at a very reasonable rate.
Have a look at his work here:
https://www.facebook.com/AL-Developments-846552508744383/
If you're not on facebook, i can pm his email address.
Dave
lewis
posted on 15/11/19 at 01:18 PM |
Thanks all, I will make some calls
