Author: Subject: Duratec - head swap
cosmicicecreamman
posted on 30/1/20 at 05:19 PM Reply With Quote
Duratec - head swap
Evening all,
I have a passing valve on my 2.0ltr Ford Duratec. I have a spare engine with a good head. They're both the high port heads.
Question I have is - can Duratec heads be swapped over or should the head that came with the block from factory be repaired?
Years ago I used to swap around engine components on various CVH, Pinto, x-flow, etc, but wasnt sure how the modern engine would accept another head.
Stephen
snapper
posted on 30/1/20 at 07:05 PM Reply With Quote
You can swap heads over.
The high port Duratec head can be fitted to the Mondeo/Focus low port head engine and vis vers
I eat to survive
I drink to forget
chillis
posted on 30/1/20 at 07:12 PM Reply With Quote
so long as they are both from engines of the same capacity eg a 2.0l head from a 2.0l engine
Never under estimate the ingenuity of an idiot!
cosmicicecreamman
posted on 31/1/20 at 09:27 AM Reply With Quote
Excellent!!!
Thank you gents.
