Author: Subject: Rear View Mirrors ?
Deckman001
posted on 31/1/20 at 12:14 PM Reply With Quote
Rear View Mirrors ?
Hi All,
Just wondering, am at the stage of replacing the tatty/broken old R6 mirrors I had fitted previously, can they be E marked, or in fact do they need to be E marked for IVA ?
Jason
pekwah1
posted on 31/1/20 at 12:31 PM Reply With Quote
Doesn't have to be e marked, see below from the Indirect Vision section of the manual:
Of course just makes your life easier if they are!
7. All mirrors must have an acceptable approval marking or have equivalent
characteristics to a mirror approved for use on a vehicle of the same
category as follows:
- The reflective surface must be encased in a protective housing
- surfaces contactable by a 165mm sphere (interior) or a 100mm
sphere (exterior) must have a radius of curvature of at least 2.5mm
– except for fixing holes or recesses less than 12mm wide, which
must be blunted
gremlin1234
posted on 31/1/20 at 02:51 PM Reply With Quote
there are requirements for minimum 'reflective surface' size too
8. An interior mirror must be a minimum of 40mm high by 80mm long (see Note 2 & Figure 1)
9. An exterior mirror must be a minimum of 40mm high and 70mm long, and be able to incorporate a measurement parallel to the height of the rectangle at least 70mm in length within the lens. (see Note 2 & Figure 1)
Deckman001
posted on 31/1/20 at 07:05 PM Reply With Quote
Cheers guys, that sounds perfect as have found some cheaper than OE ones and i think they look great like the original ones.
Wahoo getting there !!
Jason
