Author: Subject: making a nose cone
skydivepaul
posted on 2/3/20 at 09:21 PM Reply With Quote
making a nose cone
I am looking to build a nose cone for my lotus 49 simulator (full size)
I built the sim last year and have been toying with the idea of making a nose cone.
Unsure as to make a plug, mould then a fibreglass nose cone or just try to make one from scratch out of hardboard / plastic or something else.
I am thinking a fibre glass nose cone would be best as athough it is a fairly simple shape it does have some compound curves.
Any advice appreciated
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
steve m
posted on 3/3/20 at 07:54 AM Reply With Quote
As it isn't going to be on a car, and weight not an issue, I would use "modeling foam" to make the structure
to the best shape, and then "modeling clay" to make a nice outer skin
Both of these techniques are messy, and really need to be done outside
and don't forget some pics, as the sim looked brilliant !!
steve
skydivepaul
posted on 3/3/20 at 12:12 PM Reply With Quote
Hi Steve,
cheers I'll look into that and of course will post some pics
HD CCTV
IP security systems
gremlin1234
posted on 3/3/20 at 04:52 PM Reply With Quote
as above, for a stationary one off, you could make it with plywood and filler, or clay, and just use that.
but also
if that comes out nice enough you could then make a (fiberglass) mould from that, to be able to produce more
skydivepaul
posted on 3/3/20 at 10:54 PM Reply With Quote
but also
Yes that was an option I was looking at. although for a one off it is making the part 3 times, plug, mould and part.
Never done any fibreglassing before except for bodging a wing on a mini once upon a time!
HD CCTV
IP security systems
907
posted on 4/3/20 at 08:53 AM Reply With Quote
There's only one material to make nose cones from..... You know it, I know it.
MagicalTrevor
posted on 6/3/20 at 01:00 PM Reply With Quote
Use modelling foam or the stuff they used for flower arranging, available in big blocks. You can sand it down and then use a thin layer of filler over the top before painting/wrapping.
skydivepaul
posted on 7/3/20 at 02:13 PM Reply With Quote
cheers Trevor, my wife is a florist so has plenty of oasis in her workshop. Might get me in trouble if I use that much though!
HD CCTV
IP security systems
ste
posted on 8/3/20 at 10:42 AM Reply With Quote
design it in cad, split the model and 3d print it. glue it together and youll be right.
it doesn't sound structural if its on a sim.
you could even use the 3d model to make the buck to fibreglass
MagicalTrevor
posted on 8/3/20 at 10:54 AM Reply With Quote
https://youtu.be/XeeSsmsm9h0
This is a really good guide incorporating 3D design and ultimately doing what I recommended above
