Author: Subject: Rotary welding table
mark chandler
posted on 6/4/20 at 11:58 AM Reply With Quote
After plenty of years struggling to weld round objects and with time on my hands I had a google and have come up with this.
Total cost, I had an old chuck is around £25
Bearings £8
Shaft from scrap
Myford gears, lying around
240v >12v power supply £5
12v speed controller £5
12v low ratio motor £8
Off cut of steel sheet
Rotary welding table inside
Rotary welding table outside
I need to wrap the shaft with some braided earth lead so the bearings are not destroyed when running, the electrical bits are fully isolated from the case.
All I need now is something to weld, I have some throttle bodies to mate to a manifold so this may be my first use
Mr Whippy
posted on 6/4/20 at 03:06 PM Reply With Quote
Yeah that's very fancy, one of those tricky tasks made a lot easier. You could use a relay to trigger the motor from the welding torch trigger (assuming your MIG...) or use the foot controller for a sewing machine??
£25 pounds though, hmm you should write a book
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
mark chandler
posted on 6/4/20 at 05:10 PM Reply With Quote
Haha
Yes, may be many times more than expected..
I,m hoping to up my TIG game, next will be a fixture to move the torch in a straight line so I just have to feed wire in pulse mode.
Angel Acevedo
posted on 6/4/20 at 05:26 PM Reply With Quote
Could you install a copper band interference fitted to the shaft and use some heavy duty carbons a-la electric-motor-brush to achieve the desired functionality?
mark chandler
posted on 6/4/20 at 09:49 PM Reply With Quote
Interesting thought that, the shaft turns slowly, maybe 10rpm flat out although in use maybe 2rpm, the shaft is a bit of stainless I had laying around that machined up to a very smooth finish.
I have some phosphors bronze so could make a sprung loaded hinge and run this against the shaft.
Food for thought thank you.
[Edited on 6/4/20 by mark chandler]
big_wasa
posted on 7/4/20 at 11:08 AM Reply With Quote
Making something similar is just about on the very long to do wish list.
Simon
posted on 8/4/20 at 08:25 AM Reply With Quote
Have a look for a you tuber called This Old Tony. He built one recently and his vids are quite amusing
mark chandler
posted on 14/4/20 at 08:02 PM Reply With Quote
This old Tony is very good, it’s a hybrid of his although the motor despite the low gearing is not that powerful so I may upgrade to a stepper motor.
Just need a welding project now!
